Question about Protron PLTV3250 32 in. LCD Television
Protron LCD 3250
Cannot power TV up. It flickered a couple of times then went down. I've replaced the 4amp/250volt fuse.... nothing.
  • Anonymous Nov 13, 2008
    i have no power does anybody know where to buy a power supply for this T.V.
  • Protron Master
  • 5,568 Answers
Replacing the fuse more than once is not productive and it may not have been at fault anyhow.
If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Nov 23, 2008
How do i tell the amps for a t4ah 250v ceramic fuse? and is there a substitute for it? it came out of a microwave oven behind the panel.
That is a Time delay 4Amp High break rated 250Volt Sand filled Ceramic Fuse link
Hope that explains it for you. If you aquire a new fuse it must be Time delay 4Amp Ceramic type otherwise it could be a hazard.
Jan 03, 2011 | Televison & Video
PROTRON 32'' LCD TV PCTV 3250 NOW NO POWER I HAVE IT FOR ABOUT 2 YEAR
If no light ( standy light) then tv may be fused ie , plug fuse, internal fuse, If STANDBY LIGHT ON BUT NOT WORKING THEN, This is power supply failure I would say, but not for the novice , it could be capacitor failure, these are cheap usually but takes time to fit.
pete
Nov 10, 2010 | Protron PLTV-32 Television
Protron pltv 3250 power cord
It is the same power cord as used for your PC, NEMA5-15P to IEC C13.
This TV has known problem with power supply, so keep an eye on it.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 18, 2010 | Protron PLTV3250 32 in. LCD Television
My remote control went out for my Protron PLTV 3250. What can I replace it with. It seems nothing works not even one I ordered on ebay!!
Try at remotes.com This is the one that they indicate is compatible with your TV: http://remotes.com/store/protron/pltv3250.html
Dec 21, 2009 | Protron PLTV-32 Television
I have a protron PLTV 3250 I was watching Tv and the TV went out.
no it is your power supply it may have primary power but if you look closely you will see several puffed up capacitors these blow because of the fet near by let go and is not avail you can get a new supply for about 60 bucks from ramplus.com get the fsp number off the supply ex fsp-194
Sep 18, 2009 | Protron PLTV3250 32 in. LCD Television
Tv has no power - Protron PLTV 3250
Look at the othewr posts for Protron PLTV - 3250. You need a power supply.
Aug 16, 2009 | Protron PLTV3250 32 in. LCD Television
No power to my Protron PLTV 3250. What can I do
My Protron PLTV - 3250 just went out yesterday. By this I mean it turned on and went out in a few minutes. I left it off and today it completely died. I opened it up because I always think I can repair things. So what I found is a burn mark on the curcuit board of the power supply which is located inside the tv. On the other side of the burn mark is a (zener diode), this diode is burned out and therefore the power supply is not working. I am going to Radio Shack tomorrow Monday Aug. 31, 2009. The diode is very tiny but should be easy to replace with a sauder gun because this diode has place holders to hold the tiny diode in. If this does not work at the top of this page is a link that says power supplies for your tv for sale. I am going to check it out. Anyway just so you all who know about computers= the tv power supply is similar to the power supply on a computer. Just like a computer power supply comes in a case that you install into your computer and then you just connect the connectors to your motherboard and drives. Well in the tv the power supply is stand alone also, you can disconnect the wire connections in the tv and replace the power supply. If you notice the power cable to your tv is the same as a computer power cable, so the power supply in the tv is much the same as a computer power supply. I hope this helps you.
Mar 05, 2009 | Protron PLTV3250 32 in. LCD Television
Protron PLTV 3250 Parts
Ask and you shall receive. Shopjimmy.com seems to have them in stock. And people sell TV parts on Ebay all time. I hope that helps you.
Feb 01, 2009 | Protron PLTV3250 32 in. LCD Television
TV DEAD
hello, the first thing to do is to check the power supply, meaning check the main fuse and burned components,if do not have any electronics repair skills call the repairman, but first carefully open the set and check the all the fuses.
Dec 19, 2008 | Protron PLTV-32 Television
Protron PLTV3250 32 in. LCD Television Logo
78 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
