We noticed that the freezer section defrosted and it refrosted itself but most of the time defrosted..
SOURCE: Refrigerator
It may well be the defrost control. They have a turn slot to advance them if the timer quits. You need a little aptitude to find this and check it. If you think you can do it let me know, and I will walk you through it.
SOURCE: Our freezer leaks water. We had a repairman look
hi there,
yes, freezers are self-defrosting but if it breaks, there's no way it can self-defrost.
SOURCE: About a year ago my LG LRFD 23850TT French door
that's the way it works ;-(
you should defrost your frig every 6-12 months.
look here for a fix if you don;t do that.
Have fun
Avi
SOURCE: L G Multi Air FlowGR359SQ Fridge/freezer, freezer
Clean drain under freezer coils.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
The manual defrost reset procedure.
The procedure is as follows: ----
First unplug the unit
from main power outlet. Then empty whole unit completely. Then keep both the
doors open. Wait for 24 hours. All the ice collected on the coils and in the
freezer section will get melted. Clean the water from the sections.
Then Connect the power cord of the unit to main power outlet after 24
hours/.Then set the temperature to normal in both fridge and freezer section.
It will take near to 4 hours to get run in its proper cooling cycle. Then
check, if the problem returns again. Then its defrost board problem.
If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
