Question about Epson Stylus CX9400 Photo Printer
Epson Cx9400Fax Paper Jammed
I am not able to locate where the paper jam is or how to open the printer to reach the jam. I have tried everything the instructions manual said but the paper is jammed further into the printer. Also why is the paper not feeding properly into the printer. I have seen others with similar problems. I have tried to feed one by one and also a few at a time making sure that the paper is not creased. Thank you for your help.
  • Anonymous Jan 07, 2009
    Paper will not feed beyone one inch. Creases paper. Cannot see any reason for jam. Cannot get to area.
    Scholar:
  • 134 Answers
I hope it helps!!!
Posted on Dec 12, 2008
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
When trying to print the printer pulls in more than 1 sheet of paper causing a jam in e.ta
just folowe the steps
1. 1
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2
Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3
Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4
Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5
Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6
Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7
Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Apr 21, 2010 | Epson Aculaser C1100 Printer
My CX9400Fax printer has a paper jam every time it tries to print. As the paper starts to feed into the printer, the bottom left pulls in and the paper is then feed in crooked causing a paper jam every...
hi
hey i had the same prob til about 5 minutes ago ,, i kept pulling and playing with the jammed paper under the lid where you change the ink,, and finally on the left side ,,a blue piece of soft plastic material came out ,,now it works great ,,i have no idea where it came from but maybe it will help you lets hope
Dec 13, 2009 | Epson Stylus CX9400 Photo Printer
Epson stylus CX9400fax.....paper goes in crooked then jams
take the paper out and tap it ,then put in the fax
that might work.
Nov 14, 2009 | Epson Stylus CX9400Fax InkJet Photo...
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Epson dx8400 printer paper
Look on the back of the unit, and you might see a panel that can be removed for just this sort of situation. try to bend or lift it out gently, and you may be able to see the paper from there. Also, make sure the cartridges are taken out before you try to dislodge the paper, they might be blocking the jammed paper from your view. Needle nose pliers work great for getting out paper if you can't reach it with your fingers.
Sep 22, 2008 | Epson Stylus Photo R300 InkJet Printer
How to fix paper jam Epson CX3650?
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
CREDITS: nanicool
IF YOU DONT GET FIXED WITH THIS THEN PLEASE REPLY BACK.
I SHALL BE GLAD TO HELP YOU WITH YOUR PROBLEMS.
THANK YOU
REGARDS
SWEET RASCAL
Jun 28, 2008 | Epson AcuLaser C3000 Printer
Epson Stylus CX9400 Photo Printer Logo
700 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
