Question about Apple MacBook Pro PC Notebook
Recording to Cubase
I can play back sound out of cubase but cannot record into cubase,Do I need some type of driver or different sound card??
    Problem Solver:
  • 19 Answers
Does the laptop have a built in mic.??? if not your going to need a mic. also, make shure the mic is connected to the rite jack, there should be three, and only one works... Good luck!
Posted on May 02, 2007
SOURCE:
I just bought this mixer and can't seem my existing Cubase recording software to recognize it for recording. Do I have to run the mixer thru my existing interface or can the Cubase setups be modif
The mixer allows you to use the USB connection for recording without having to use an additional interface. Make sure that you have all of the proper drivers installed for the mixer. Regardless of whether you're using Mac or PC, you should be able to see the device in your list of available Audio Devices. If you do, you need to adjust the proper settings in the Cubase Audio preferences to make use of those inputs.
May 29, 2013 | Mackie PROFX12 Professional 12-Channel...
Recording on cubase le4 using my tascam us122 mk2
You're probably not recording through your tascam interface. Go to control panel -> sound, and then select the us122 as your default sound device. Close cubase and open it again. Then go to devices -> device setup, and then under your asio drivers, select asio us122. That should solve it
Oct 25, 2009 | Tascam US-144 Sound Card
Recording with cubase problem
Need to set it to stereo. There may be a switch on your mixer, and you will also need to change the settings in Cubase to record in stereo, not mono.
Jul 30, 2009 | Lexicon Omega Desktop Recording Studio...
No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Sep 26, 2008 | Tascam US-144 Sound Card
H4 randomly stops recording on cubase le
I may possibly have solved this. I didn't realise that when I log off from Cubase, the ASIO driver returns to the Multimedia ASIO driver, which seems to be the default setting.
Every time I want to record with the Zoom H4 in future I'll need to reconfigure the ASIO driver to the H4 one.
I thought once I'd set the driver, it would remain there every time Cubase booted up. Apparently not.
Aug 28, 2008 | Zoom H4 Handy Recorder
Recording with condensed mic and phantom
Some (very) basics with any live audio recording:
  • Have a very very quiet space in which to record, with good acoustics (this means a room that will give a flat sound, preferably one with carpeted walls and celings, but any small, well-furnitured room should do).
  • Do not mix with the interface. Simply put the gain as high as possible without clipping and mix later in your recording program (Cubase, in your case). You can always bring the level down, but trying to gain an already recorded track will introduce noise.
  • If you are recording vocals, use a pop filter. When recording anything, experiment with different mic positions to attain the best possible, clean sound.
Jul 25, 2008 | Tascam US-144 Sound Card
Cubase REcording/Playback Problems
check first the sample rate maybe its to high like instead of 44k. its in 48 96 or something like that so the buffering isnt catching with the recoding . alogn with your lattency configuration must devices are ok in 512 latency.
and also be shure not to be recording directly to tyour external hard drive
in case of plugin overload issue it would not stop recording suddenly it would slow down first with some crackles and then stop or must shure freeze.
so impretty shure its somethin else.
hope it works
good luck
May 10, 2008 | Steinberg Cubase SX3
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Nuendo/Cubase sound cuts off
I chased this same problem with a friend's laptop using Cubase. Additionally, he had several recurring pops at high end, in regular intervals, with 23 seconds of trouble free gaps in between incidents. Eliminated hardware problems, so I contacted some Cubase user groups and they indicated their older software was not compliant with the newest hardware... in other words, they suggested he buy a newer version.... He did (gasp, sticker shock... the horror) and the problem disappeared. Might be all that is wrong for yours, if your desktop has newer hardware and older version of Cubase.
Jan 31, 2008 | Intel Steinberg Nuendo AudioLink PCI 96...
Apple MacBook Pro PC Notebook Logo
109 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
tylerbell49
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
