Question about IBM Wheelwriter 30 Typewriter
IBM wheelwriter 25 message: a box and diagonal line thru it and the number 215.
When I start my IBM typewriter, there is a box with a diagnonal line thru it and the number 215. It won't let me type and the carriage will not move. I've already had the power supply replaced. I returned it to the repair person, he brought me in the back and showed me the typewriter worked. I bring it home, and it doesn't work and I get the same message. What could be wrong?
  • IBM Master
  • 3,594 Answers
Code 215 is a printwheel error. Remove the P/W and look for debris in that area, if you have some compressed air source blow this area out, if this dosen't do it the P/W sensor or the LED are probably going bad.
DickyO
Posted on Nov 03, 2008
IBM Wheelwriter 30 Series II is showing an error code of 215 with a box with a slash through it and am unable to type on it
215 is a Print Wheel error. Remove the print wheel, look for debris in the P/W area, if you have a compressed air source blow the P/W area out. If these don't work the P/W sensor is probably bad.
DickyO
Sep 07, 2011 | IBM Wheelwriter 30 Typewriter
My IBM Wheelwriter 30 Series II has a message of a box and an X in it and then the numbers 215 can someone tell me how can fix this?
Check to be sure the printwheel to be sure it is properly installed, check for debris in the P/W area, If these are OK then the sensor is probably bad.
DickyO
May 28, 2010 | IBM Wheelwriter 30 Typewriter
Will not advance or return to left margin.
215 is a pwintwheel not being detected. Try re installing the P/W look for debris in that area, if you have a compressed air source blow out that area. If these fail tou will need a P/W sensor, LED or both.
DickyO
Apr 06, 2010 | Lexmark Wheelwriter 3500 Typewriter
What does a square with a line through it with the number 215 mean, when it will not type?
215 means that your keyboard is bad. You can try my tip under WW1000 or contact Geo. Beters Co. @ 800-392-8085 for a rebuild.
Tell them O'Reilly sent you.
DickyO
Feb 26, 2010 | IBM Wheelwriter 30 Typewriter
In the display box there is a box w/ a slash through it and the number 215 following it. everything seems to be locked up - what do I do?
The book says bad keyboard. Try unplugging and repluggin the 2 keyboard ribbon connectors. If that fails contact Geo. Beyers Co. @1-800-392-8085 for a rebuilt keyboard.
DickyO
Aug 17, 2009 | IBM Wheelwriter 30 Typewriter
IBM WHEELWRITER 30 SERIES II
I believe a 215 code is a bad printwheel sensor. You need a tech.
DickyO
Mar 05, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Series II Typewriter 6787
The book says turn the T/W off wait 30 seconds and restart, if condition returns call for service. However you might try removing the batteries and unplugging the machine waiting a few minutes and restarting. CAUTION ALL THE MEMORY WILL BE LOST!
DicktO
Jul 16, 2008 | IBM Wheelwriter 30 Typewriter
Ibm wheelwriter 30 series 2
215 indicates a printwheel error. Remove the printwheel, look for debris in the P/W cartridge and the area where it sits blow out the P/W area with air if the problem dosen't go away the sensor is probably bad.
DickyO
Apr 01, 2008 | IBM Wheelwriter 30 Typewriter
IBM WheelWriter 3500
Try pressing and holding code key while pressing "L" release "L"
and type 001 release the code key. If this solves the trouble but it comes back on the next power up the keyboard is bad.
DickyO
Mar 25, 2008 | Lexmark Wheelwriter 3500 Typewriter
IBM Wheelwriter 30 Typewriter Logo
211 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
