Question about Canon imageRUNNER C3200 Color Printer
Canon MF8180c just bought this printer one month ago, have a E071 error
  • Canon tech CROATIA
    Canon tech CROATIA May 11, 2010
    E071 ITB home position sensor fault Check the connector of the ITB home position sensor. Replace the ITB home position sensor. Replace the DC controller PCB. E078 secondary transfer roller drive mechanism fault Check the connector of the roller drive sensor. Check the connector of the roller drive clutch. Replace the main drive assembly (roller Drive sensor). Replace the drum cartridge (roller drive cam). Replace the DC controller PCB. E100 scanner fault Check the connector of the laser scanner assembly. Replace the laser scanner assembly. Replace the DCNT Borad. E196 DCNT Borad memory fault Replace the DCNT Borad. E197 engine communication error Replace the DCNT Borad. E747 SCNT board memory fault Replace the SCNT Borad. E805 fan fault Check the connector of the cooling fan. Replace the cooling fan. Replace the DCNT Borad. Code Main cause/description Remedial action THE BIG QUESTION IS: DID YOU REMOVE ALL PROTECTIVE ELEMENTS INSIDE?
  • 1,219 Answers
E071 error stands for ITB position sensor fault,so you may try to check if the ITB belt is ok, if there is no paper left overs or similar, but this error can occure when the main board ( dc controller ) is defective.
Posted on Feb 17, 2010
Canon isensys MF8180C show System Error E100 while printing operation.
This error means: there is a problem with the laser unit. Dirty or faulty
Jun 20, 2015 | Canon imageCLASS MF8180C All-In-One Laser...
Error E071 0007
A E071 deals with the transfer drum unit engaging unit. Has the transfer sheet been replaced lately? There is also a drive unit on the back side of the copier for lifting the transfer drum. There is a senor that may be dirty or damaged.
Dec 25, 2010 | Canon CLC 1140 Copier
Error Code: E071 0007
I got an error code on my canon clc 1100:
E071 0007
Aug 19, 2010 | Canon CLC 1110 Copier
How to fix canon code E071
Here is an answer from DZJOLLA:
"hi there
well ive had years of experience on these machines and seen this error loads so ure in lucksmile.gif
1st off are u a tech? if not do not read any further as this post will only make sense to a tech.
i can only imagine this machine is old now. most of the time its the connectors that cause the e071 error. how many prints has copier done? have the connectors on the carraige frame and on frame of machine ever been changed? if not thats more than like causing your issue.
is your TD unit spinning ok? or is there resistence somewhere, if so this might also cause this error. the manual points to the 3 timing sensors in the TD unit IE. timing plates arent arriving on time for those sensors, but again everything relates back to the connectors as this is where it gets its voltage from. blow the sensors out as well.
change the connectors mate would be my 1st conclusion for that errorsmile.gif let me know how u go please...
the other errors arent even coming up in the manual which points even more to the connectors.:
Apr 28, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon color imageclass mf8180c, Iam getting '' SYSTEM ERROR E071
I had the same error message E071. Had to call out an engineer who diagnose the Drum 701 was leaking toner - this got on the electrical contacts at the bottom of the drum. He cleaned the contacts on the drum and in the machine - put my old Drum in there and all is OK. The drum was 9 months old and not had much use so I am trying to get a replacement from Canon under warantee.
Apr 06, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon ImageClass MF 8180c Error Code E071
i had the same problem, had to replace the drum unit
Mar 10, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
CANON i-SENSYS MF8180C
hi happy new year
Dec 29, 2008 | Office Equipment & Supplies
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
I have a system error e071 on mf8180c image class.
Hi, as per the manual it says
Solution
Jul 25, 2008 | Office Equipment & Supplies
Canon imageRUNNER C3200 Color Printer Logo
315 people viewed this question
old marine
old marine
Corne Viljoen
