Question about Maytag Neptune MAH5500B Front Load Washer
MAYTAG Mah4000 front loader washer
Our Neptune keeps shutting off under 1 minute of running.  We replaced the wax motor and also the circuitboard but it still is shutting off.  It doesn't matter if it just started a cycle, is before spinning or also before it washes.  It also sounds like the wash bin keeps turning- does not stop and reverse direction like it should.   Please help!
  • miklindy28 Nov 01, 2008
    I ran the proper tests and got the 50 rpms on the drum so it should be ok unless you know otherwise.??
    Genius:
  • 1,122 Answers
HAVE YOU CHECKED THE MOTOR CONTROL BOARD?IT IS LOCATED INSIDE THE FRONT RIGHT BOTTOM OF WASHER BEHIND FRONT PANEL,LET ME KNOW IF YOU FIND ANYTHING-MIKE
Posted on Nov 01, 2008
What is the value of R-11 in the maytag ,MAH4000 AWW it's in the door lock wax motor for the hinh speed spin
The R-11 is on the control board, not in the door lock or wax motor. Value is 3.9KOhm, plus you'll need to replace the Q6 triac if R-11 is burnt out, as it's also dead.
Jun 17, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Model MAH4000, will not spin out, door lock will
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
May 12, 2010 | Maytag MAH6700AWW Neptune Front-Load...
MY MAYTAG NEPTUNE MAH4000 WILL NOT DRAIN OUT OR SPIN
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
Machine keeps tumbling after wash cycle is completed.
Make sure that the replacement R11 is in fact connected to pins 1 & 2 of the Q6 triac. If the copper trace on the backside is open on either leg of the R11 to the Q6 then the wax motor will stay energized and that will cause the tumbling after the wash cycle.
See www.neptunehelpsong.com for a new funny song that explains the Maytag Neptune door latch wax motor issue.
Jan 21, 2009 | Maytag MAH6700AWW Neptune Front-Load...
1999 Maytag Neptune front loader
Have you replaced your 12002535 door latch wax motor if you have a MAH3000, MAH4000, MAH5500A or the 2000 stacker? These wax motors will eventually fail on every Neptune shipped. When the wax motor fails the upper machine control board be damaged and you will lose your spin function which leaves your clothes soaking wet. There is a website that offers a repair kit to see if your control board is useable again. Don't keep starting machine because you might cause further damage to control board and the motor control board located near the floor until you see if R11 is burnt on the upper machine control board located behind the timer.
See www.neptunewaxmotor.com for more details and step-by-step disassembly photos.
Sep 21, 2008 | Washing Machines
My Mother's Maytag Neptune front load washer has water left under the drum after the final spin cycle. I am not sure that this is normal. Please advise.
This is normal to hear water sloshing under the drum when machine is done washing and you spin the drum. This is part of their water balance method to help spinning procedure. I called a Maytag repair shop and they helped with my question.
Jul 23, 2008 | Maytag MAH6500 Neptune Front Loading...
Front loader maytag neptune wont start
Check the door switch. Sounds like the wax motor is not fully engaged.
Jan 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
226 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
