SHARP AL-1216: HOW TO REMOVE H4 ERROR CODE
MY COPIER SHOWS H4 AND I NEED THE MANUAL FOR SOLVING SIMILAR ERROR CODES.
  • TUCHCHAR Nov 02, 2008
    thanks for the attention, but how do I go into the program. There are no buttons for numbers and no # visible.
  • repsteinca Apr 19, 2009
    Exact same problem, and that PDF link is useless.
  • 62 Answers
Www.tinli.com.hk/PDF/AL1216.pdf
Hope this helps.
paul
Posted on Nov 02, 2008
TENHO UMA COPIADORA SHARP 1651 CS E ESTA COM O ERRO H4 EPEDE PARA CONSULTAR GUIA USUARIO. O QUE FAZER?
Posted on Sep 11, 2009
Clearing service man on 5320 sharp copier
Hello, NICOLAS
Let me give you, a url when you can find sharp error codes and fix by youself, if you have any other cuestion, please write a comment, im here for help you.
How to solve the h4 subcode 00 error message on sharp AL-2030 copiers
http://www.en.rellenadodecartuchos.com/2014/05/how-to-solve-h4-subcode-00-error-message-on-sharp-al-2030-copiers.html
thanks for comment if need more help
Nov 16, 2015 | Sharp Office Equipment & Supplies
What is the causes of h4 error in sharp al-1216 photo copier
The h4 error code isn't complete. There should also be a "sub-code" which defines more precisely where the problem is.
May 22, 2015 | Sharp Office Equipment & Supplies
What Error H4 for Sharp AL-1216?
It is the fuser temparature error, may be with the heater rod, thermistor or thermostat, or with the mcu pwb. rate this and vote for this
Apr 06, 2011 | Sharp AL 1631 Copier
I have a Sharp Al 1566 Photocopier,Printer,Scanner and it has encountered a problem which is SYSTEM ERROR (H4-00) so how can I fix the problem?
H4-00 = Low heat roller temperature detection. This is usually caused by either a blown heat lamp or a blown thermal fuse.
Sometimes the error can show up for no particular reason. Try resetting using the following sequence:
#,*,C,* (hash, star, clear, star) then enter '14' and then press the start button.
The machine will reboot. If the code comes back you'll need to check the lamp and fuse for continuity (having removed the fuser from the machine first!)
Hope this helps.
Feb 02, 2011 | Sharp AL-1655CS Copier
I HAVE A SHARP AL 1631, IT SHOW ME A 4 CODE, HOW CAN I TO SOLVE THIS
their is no A4 code,if you mean H4 try to reset it by simulation 14
Dec 26, 2010 | Sharp AL 1631 Copier
Sharp AL-800 is blinking H and 4 what could be the problem?
the error code H4, means that an abnormal temperature was detected in the fusing section (the hot roller was not working properly during the initialisation of the printer), to solve the problem;
  1. unplug the printer from the power source
  2. wait for 10 mn
  3. plug the printer again to the power source
  4. switch on the printer
if the error H4 still displayed, you need change the fixing unit, that must be doing by a qualified technician,
Dec 14, 2010 | Sharp AL 800 Copier
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
Can you help me for may copier sharp AL 1216 with the error code H4
Press C, Auto, C, Auto keys in that sequence whole process should be within 5 sec, enter 14 print.
Nov 12, 2009 | Sharp AL-1217 Copier
MESSAGE: SYSTEM ERROR (H4-00) REFER TU USER GUIDE
We had this problem when the power was fluctuating in our building. I called Sharp and they told me to clear this condition with the following code: #*C* and when the screen shows 00-00 enter 14 and press the green copy buton. This worked on the AL-1655CS. On the AL-1631 we had to do a similar thing: C<auto>C<auto> 14 <copy>
Jun 06, 2008 | Sharp AL-1655CS Laser Printer
1,601 people viewed this question
k24674
jasbo
jasbo
