Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
Cannont get SD card to work
Try to use SD card with my Moultrie I60 GameSpy camera. Out of 5 cards, only one works. Use sandisk as recommended, any idea?
  • Anonymous Nov 23, 2008
    Can't get sd card to work
  • Moultrie Expert
  • 296 Answers
What size SD cards? I wanted more pics, so I got some 8gb HCHD cards...don't work...they were Sandisk(best).
make sure your cam is compatible with cards you're using
Posted on Feb 20, 2010
Sd card keep reading ureconized file format
FAQ Proper Use of SD Cards with Moultrie Game Cameras
Question appears to be from some months ago, but Moultrie web site shown here suggests copying photos to a computer if possible directly without using the camera itself. Then it suggests reformatting the SD Card itself.
Feb 08, 2016 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Camera shuts down after 1-2mins an does not take pics
Just to let you I had Moultire m-80 when I used a pny sd card it ruined my camera. They were kind enough to replace it for me. I just use what they recommended do not have any more problems. I only delete pic on my computer and not digital camera. Try doing a hard reset take everything out turn to the on position for about 2-3 minutes after 3 min put brand new battery's in it while on the on position should say no card at this time. If doesn't turn camera off put sandisk sdhc card in it. Test camera again if still not working Moultire will help you I have talked them great customer service.
Nov 26, 2013 | Moultrie Game Spy M-880
What sd card should i be useing
Any SD memory card should work. The bigger the more images it will hold.
Moultrie offers 2G up to 16G so go for price from any place you can find SD cards.
http://www.moultriefeeders.com/catalog.aspx?catid=cameraaccessories
Aug 27, 2012 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My moultrie trail game camera d-40 will not store pictures on memory card. I have tried multiple memory cards. The card I have been using is not very old and has worked fine until now. Camera is showing...
Is the small switch on the side of the SD card pushed up toward contacts? Has the card been formatted by a PC(A NO-NO)?
Remove card;turn camera on..go to setup; press up arrow once to get "DELETE ALL IMAGES NO?";press select button to get flashing "NO"; press up or down button once to change flashing NO to flashing YES; press select once...should get "DONE";press select until back in "SETUP...Turn camera off insert SD card and try again...may need new SD card.
Oct 24, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
On model MFH-DGW2.1 it will not work with sd card. it will not recongnize card, i can not get it to change modes or get camera to work. take card out and camera works
SD card 101: the 2.1 MP cam is not compatible with newer sd cards...get standard SD class 4 or less; SDHD(high def);SDHC(high capacity);and classes above 4 may not work(class 4 SD cards usually have a 4 stamped just under the SD on card's label.
Aug 07, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Error code 000480, will not allow me to delete internal memory, says redo. is not recognized when it is connected to my laptop. brand new batteries & sandisk sd card. help!
Error code 000480="cam mod test/comm error...it is not communicating with SD card...may be bad main board ...get my parts from other defective cameras...Moultrie will tell you to buy new camera.
Jun 22, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie d40 locks up when I put the sd card in???
make sure card lock switch is forward toward contact strips fully.
Sep 03, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie will not go into picture mode with SD card
these cams are not compatable with some SD cards; ck your manual for card compatability
Aug 24, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie i60 game cam takes pics constantly while
If within warranty, with valid receipt.....send to Moultrie
Jul 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie GameSpy 4.0 states SD Card is locked when it is open. How can this be repaired.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jun 16, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
181 people viewed this question
Top Moultrie Cameras Experts
AZBen
AZBen
Steve
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
