Question about Intel D101GGC Motherboard
IDE controller not working properly
I have been using Intel 101GCC Mother board since one an half years, but suddenly I am facing some issues interms of Harddisk dvdroms detection.
My PC is configured with a 80gb IDE hardisk and 2 DVD Writers, but now all of sudden it fails to detect any of these IDE devices, but sometimes if I remove the DVD writers and only connect the Hardisk it detects the harddisk but when I connect the DVD rom back it fails to detect both . I tried connecting one to Primary IDE and the other to Secondary IDE, still it fails.
Eagerly awaiting for the experts assitance / solution
Thanks
Vamsi
  • Andy Bathgate
    Andy Bathgate May 11, 2010
    also make sure the larger capacity cdrom is set to secondary master and the other to secondary slave and hdd is primary master. you could also check that busmastering is enabled in the bios
  • Andy Bathgate
    have you checked the jumpers at the rear of the devices and set them to master or slave instead of cable select or vice versa
  • 94 Answers
Having done these things get in touch and we will go from there
Posted on Nov 01, 2008
I have D945GCCR intel mother board ,i got an ide to sata adapter to recognize dvd writer ......but mother is unable to recognize it ......r there any driver to may it work
This board directly supports IDE. Do not use the adapter. Use the IDE port on the motherboard directly using a standard IDE cable. Good luck!
Jun 14, 2011 | Intel D945GCCR Motherboard
My Computer working properly but some time suddenly monitor turn off (not standby) that time restart / power off button not working.only way to restart/off computer unplug power cable. after restart same...
Hi friends ,
It is *********** board problem,Because the over heating. Go to bios and set the FAN control disable.
If same problem
Change the CPU FAN .
If the problem same .
You will think, the censer of the mother board, has damaged and that's why,censer of the mother board think that CPU is cross the temperature limit. It is the main reason.You need another mother board,sorry to say you.
Hope it will help you.
Dec 20, 2010 | Intel D915GAV Motherboard
No display on mother boards
Are these computers all emachines? this board is normally used in the emachine range of computers and have a problem with the architecture Call me ? chris http://www.motherboardsrus.net 07926-106150
Jun 05, 2009 | Intel D845GVSR Motherboard
Will not boot,bios does not show a hard drive,only two CD drives
The peripheral devices as Hard disk and cdrom is not connected with the IDE cable or has loose contace. Even power cable of devices is not properly done or left out. So you need to check the IO IDE cable connetions and the power cable connections of the devices being connected to the mother board.
Mar 30, 2009 | Intel D865GBF Motherboard
Problem getting hard drives to run
check the power supply. some time power supply not suppling the proper voltage to the accessories.
Nov 26, 2008 | Intel Motherboard
I wanted to know whether ASUS A7S266-VM/U2 will support seagate 7200.10
M/Boards support all makes of hard drive
Are you sure you connected it correctly
The wide ribbon cable that goes in the rear of hard drive should
1) Be connected to M/board in the No 1 connector with the stripe on cable to the No 1 pin
2) the stripe on cable should go next to the 4 pin power plug on hard drive
Also ensure your BIOS is set to Auto detect of driives
Aug 30, 2008 | ASUS A7S266-VM/U2 Motherboard
Dell optiplex gx260 mother board
It would be easier to order the cable and front panel board assy as one. easy on ebay.
I have worked on them for years and never bothered to trace them out. and dell doesn't post the pinout anywhere.
If you can't find one I can get it for you cheap.
Mar 02, 2008 | Intel Motherboard
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
Display
I have Intel Jetway 945 Mother Board, I checked the Processer and Ram, And SMPS it is working properly, but I am facing display problem.
Oct 29, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel D101GGC Motherboard Logo
176 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
