Question about Cameras
Panasonic Lumix DMC LX1 keeps saying lens cap still on when it not, tells you to turn off, you do and it still says the same, the lens makes a funny noise as if it is trying to go in and out but doesn't
  • 1 more comment
  • wraybarrow Nov 01, 2008
    If there is a problem with the lens how do I get it fixed and how much will it be
    remove battery and it still says the same thing
    thanks but have to get camera repaired from a professionals
    Master:
  • 505 Answers
For whatever reason, the lens has failed. This can be caused by many things: the lens motor has failed or is stuck, the gears involved in driving the lens have jammed, or, as pointed out previously, the lens itself, a series of tubes which fit into one another has become stuck. You can try GENTLY pressing down on the lens when you first power the camera to see if you can free up the stuck lens. If that doesn't work, I'm afraid you are going to have to get the camera serviced.
Posted on Nov 01, 2008
  • Indrajit Roy
    Indrajit Roy Nov 01, 2008
    The clicking sound you're hearing is the lens trying to move itself. Unfortunately, it's probably not going to be fixed by pushing on the lens. You are going to have to get the camera serviced. Sorry!
    Genius:
  • 3,422 Answers
HI,
There is one home remedy which you can try:
Tap the bottom of your camera on the table two or three times.Now remove your battery make sure they are fully charged and then insert it again.Turn on your camera and if you still face the same problem then the fault is with the lens mechanism which will require a physical presence of a tech to fix this issue.The cost of repair can be between $100-$150.
  • Priya darshan Nov 01, 2008
    IF this is under warranty then please send it to Panasonic.
  • 13,433 Answers
Try a local camera repair or you can get a free estimate from advancecamera
www.advancecamera.com/repair
  • Ekse Nov 01, 2008
    if your camera is still covered by warranty you wont have to pay for the repairs you should contact your dealer.
  • 94 Answers
Wraybarrow hello,
It seems as though your lens has a problem rolling in or out, therefore the sensor tells you it's on - because it probably still hasn't gotten inside as it should.
In some of the cameras, it helps turning the camera off, taking out the battery for a few seconds, and then putting it back in, then the camera does its own "calibration" with the battery, physically shown sometimes with a short in-out action by the lens.
Try that, and reply with any progression.
  • Tamir Meiri
    Tamir Meiri Nov 01, 2008
    Usually fixing a camera lens has to be done by a certified cameras lab, though some places might have professionals without actually having the official certification from the company.
    If the solution I have supplied you with will not be of assistance, I would suggest taking the camera to the lab, and get a price offer for the fix.
    As far as I know, the model you have is a relatively new one - meaning it is still under warranty.
  • Cameras Master
  • 19,396 Answers
That is because there is a lens problem.
It happens when lens are jammed because of a fault or because of dirt.
  • Ginko
    Ginko Nov 01, 2008
    When you get lens fault on a Panasonic digital camera, do the following:
    Remove batteries, wait 5 minutes, then put the batteries back.
    If the shutter does not open , help it opening out with your fingernail while you turn camera on.
    If the lens does not extract , help it out by slapping gently the back of the camera while you turn camera on, or pull it out with your fingernail.
    If the lens does not retract, push them in with your
    finger.
    Blow canned air on lens gears to remove dust.
    If still no luck, that means that the lens gear must be taken apart, cleaned and lubricated, and assembled back, this is a delicate job that must be done at a repair shop, if you do not want to reduce the camera to a bunch of bits and pieces.
Lumix DMC FZ35 Lens Opens and Retracts Continually When Turning the Camera on.
it sounds like it has slipped a gear in the lens.. you could try to manually push the lens in when it comes out and that might reset it but it also might break it.. best is to send it back to panasonic.. is a easy fix
Oct 01, 2012 | Panasonic Lumix DMC FZ35 Digital Cameras
Mine requests "PLEASE TURN CAMERA
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Aug 14, 2011 | Panasonic Lumix DMC-LX1 Digital Camera
My panasonic DMC-TZ4 keep opening&closing the lens non stop and telling me to turn the camera off&on again. I cant do anything else with it. What will it cost to repair this? and where do I send...
check for a reset button on camera ,,it will be small,,push with a small screw driver or ink pen without cap,,may be on botom,,check ur user manual to see,,
Nov 03, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Lumix dmc-lx1 user guide needed - any help?
Just go to the support section of the Panasonic web site and you can download a copy to your computer.
Aug 11, 2010 | Panasonic Lumix DMC-LX1 Digital Camera
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
Hi my camera is telling me to...
Is the camera turned on? Removed the Cap on the Zoom lens? Try turning it off and on, while the cap cover on the lens is removed, then press the heart button and take some photos. What specifically is the warning?
May 07, 2009 | Panasonic Lumix DMC-FZ4 Digital Camera
Panasonic DMC-LX1 Digital Camera
Your camera is then in need of service. If you need any further assistance please let me know.
Thanks,
lee
Jun 20, 2008 | Panasonic Lumix DMC-LX1 Digital Camera
Replacement lens cap for Panasonic Lumix DMC-FZ7 digital camera
Please see below for a link to the Lens Cap with String. This is an original part direct from Panasonic. Used specifically with this camera.
Lumix DMC-F27 Lens Cap with String
Mar 26, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Cameras Logo
53 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
