I have recently got my old files transferred onto DVD-R disks to put onto my new computer. For some reason when I put one in, the drive just sits there and won't read the disk. If I try and click on the drive I get an egg timer and nothing happens. Sometimes it will load the disk up after a very long time but then when I go to copy the files to my new hard drive it fails. Any ideas?
  • EssexIbiza Nov 01, 2008
    Hi this is not the problem. Surely if you create a data dvd disk with mp3s and photos on then when you put them in a dvd drive you should be able to explore the folders and copy them across by dragging and dropping them into the my photos and my pictures folders on the hard-drive?
    Scholar:
  • 195 Answers
You have to have the software that backed up your files to disk installed on the computer, the same software has to restore the files. For example, Nero will not restore files created by Slysoft. Good Luck.
Posted on Nov 01, 2008
  • Rick Drew Nov 01, 2008
    Your right, drag and drop should do the trick, I noticed you stated that its a new hard drive. I'm thinking that somewhere during installation a driver or two might not have been recognized or installed. Thank you for your rating also. I have a software that will help you Re-Install all of your drivers again without hurting your system. Send me your e-mail and I will send it to you free ASAP. The software is mine so I can do this.
How to download my file from my old computer
The simplest way to transfer files from your old to your new computer is by using USB flash drives. Just save your files from the old computer onto the flash drive then plug this USB drive in to the new computer and save the files there. If you have large files, you can also use an external hard drive to copy and transfer files.
Mar 22, 2011 | Computers & Internet
Transfer files to a new computer?
From Maxtor's web-site, download the "MaxBlast" software.
Use it to "clone" your existing disk-drive onto your new disk-drive.
It works, and it works _very_ quickly.
Other than that, use the Windows "Files and Settings Transfer Wizard" (under System Tools, under Accessories, under All Programs) to select what you want to copy (E-mail? contacts? Files? Music?) and to burn one "aggregate" file onto a DVD-recordable disk.
Then, use the same Wizard to "import" from that disk onto the new system.
Dec 18, 2010 | Maxtor Hard Drive
When trying to restore my u series 9, (ST3160022ACE) ultra ATA 160 gig hard drive I get this message: Restore was not successful. Remove any USB or Extra Hard drives taht are connected. I have no USB or...
If by "restore" you mean that you are reinstalling Windows onto the disk-drive, to restore Windows to the "as-shipped-from-the-factory" condition, then a failure of that operation can be caused by either of three conditions:
* I/O errors reading files from the CD/DVD disks (due to dust/fingerprints on the bottom of the disks),
* I/O errors writing files to the disk-drive,
* an intermittent problem with the computer's motherboard or RAM, causing "random" failures when using the computer.
So, on another computer, take the CD/DVD disks, and try to copy the entire contents (namely up to 4.7 GB) onto the 'C:' drive, watching for any "I/O errors" during the file-copy operation.
If the file-copy completes successfully, then the copy of the files can be deleted.
If no errors occur, then it's time to suspect that the disk-drive itself is failing.
Buy a new disk-drive, and disconnect the old disk-drive, and connect the new disk-drive,
and restart the "restore" operation. If the "restore" fails on the new disk-drive,
then it's time to suspect that the motherboard has a problem.
Nov 03, 2010 | Seagate Computers & Internet
Can't transfer my email files from old computer to new computer
Good Day!
To transfer files from an old computer you can use USB or flash drives, copy the files from your Old Computer to Flash drive, after copying---attach the flash drive to your new computer then copy the files and save it. This is the easiest way to transfer files.
Other way of transferring;
-You can also transfer files by Burning your files into a CD/DVD and copy it to your new computer.
-Get your hard disk from the old computer and attached it to your new computer
-Or connect/network your two computers.
I recommend USB or Flash drives, the simplest and easy way.
Hope I was able to help.
Jul 16, 2010 | Microsoft Windows XP Professional for PC
Help transferring files from computer hard drive to La Cie
Well you can ONLY transfer/Move DATA as Programs and Documents & Settings and User Directories, cannot be shifted at all. So It is only the Files and Data that can be Moved off a drive. To gain space back, Right Click on the HDD, go to properties, in properties Under the general, tab the first window, select disk cleanup, remove everything in those boxes and after, that look under Tools tab, & do a disk defragment. This may get you space back. If not you may have to get a new bigger drive, and clone your old drive, then install the new drive and reinstall the Cloned image back onto the new drive?
Mar 30, 2010 | Computers & Internet
My computer hard drive failed and I have not yet backed up my ITUNES... how can I get my songs on my new computer
If the hard-drive has totally "failed", then reading from it will be impossible.
If your problem is that Windows does not "stat" or "run", but the disk-drive physically is OK, then it should be possible to connect the disk-drive to another computer, and copy the files onto the other computer, or to burn some CD/DVD disks.
Also, do a Google-search -- there is software that can "rip" the music off your iPod/iPhone back onto your computer.
Nov 11, 2009 | Apple iTunes
I want to transfer data from my dial-up desktop, to my new laptop high-speed broadband. How?
Several ways:
1.) 4GB flash drive
2.) External USB drive (320GB or more)
3.) Burn CD or DVD on the desktop and copy to the laptop
4.) Connect them in a local or ad hoc network (not too easy)
I'm sure other expers will have more ideas...
Anyway, at the desktop, run the "Files and Settings Transfer Wizard" to gather your desktop info, such as favorites, desktop icons, My Documents, etc:
[Start]
[All Programs]
[Accessories]
[System Tools]
[Files and Transfer Wizard] [Next]
At the desktop, answwer [Old Computer] [Next]
Cintinue to answer the questions
If you have a lot of music or loots of pictures, then just transfer the "Settings Only".
After a successful transfer of the settings, run the wizard again and transfer your "Data Only"
Hope this gets you started.
Sep 18, 2009 | Computers & Internet
Transfer Email to DVD R
Save the email to your desktop (File - Save As). Put the blank CD or DVD in. Go to My Computer and open the DVD drive. Make sure the window isn't maximized so that you can see the desktop. Drag the mail file into the DVD drive window. Windows may process the file for a few seconds. In the DVD drive window click "Write these files to CD". It will burn file onto the DVD.
Mar 26, 2009 | Computers & Internet
Putting video files to hard drive
You should be able to transfer files to the hard drive. The camera will be assigned a letter in my computer. Divx software is good to convert them onto a disk and it's reasonably priced.
Check it out at www.divx.com
Dec 17, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
