Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 52" Projection HDTV Ready Model "D52W26 (No Sound)
My 52" all of a sudden has no sound. Its kinda like when you mute it. I even connected headphones and there is no output. Please help. This is the only TV in the house and I'm bored out of my mind if I can't watch TV.
email me: rubenobed@hotmail.com
Thank you
Ruben Obed
  • citawalker Nov 06, 2008
    My TV all of a suddenly does have any sound either. If anyone has a solution please help.
    Dogwalker25@yahoo.com
  • darry_kelly Dec 10, 2008
    Sound went out while watching. Picture is fine
I thank you for the advice. I checked and the TV does not have an Int/Ext switch on the back. Although it is on the menu screen. I put it on the Int setting and yet no sound. There is a plastic lid on the back of the TV which I removed and there is a module there which is making a kinda small electrical sound. And from the base of a cable leaving that module there is a blue light emerging. Could this be the problem? Yet the picture is perfect. Just no sound. And why doesnt the headphone jack work either. I am soo frustrated. Thanks for answering so quickly. Please let me know what else I can do.
Sincerely,
Ruben Obed
Posted on Nov 01, 2008
    Scholar:
  • 195 Answers
Maybe the sound is muted. Try pressing the volume up button to restore sound.
• If using S-Video or Y, PB, PR, remember to also connect the component’s left and right audio output jacks to the TV’s L and R Audio
Input jacks.
• If you're using the TV's internal speakers, make sure the INT/EXT switch on the back of the TV is put on “INT”.
• The sound settings may not be set correctly.
HDTV monitor 52 in. Model #: D52W26 Serial #: G072CU07E colors are separated, warped screen and cannot find auto convergence
Very easy repair. The ITC222 and ITC222A convergence option missing repair kit available from www.tvrepairworld.com will solve that issue. Its listed under the RCA repair kits and has the parts and the CD with repir instructions.
Mar 31, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W26- 52 " rear projectio- 3d colors,,,is convergence issue
um i think your gona meet your maker,,,your solutions are not being tolerated.. listen...to the new maker, he can and will make you learn what manners are!!
My rca 52 in projection t.v has problems powering up
Push and hold power button. If it cycles and blinks on/off in 3s or 9 times, it is a power problem. Replace the deflection board. Cost about 250.00
Jan 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green Screen, No Sound, Shuts off after 10 seconds
Almost certainly the green picture tube is shorted. This is a very expensive repair; probably not worth doing.
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Divergence not working on RCA HDTV monitor 52" D52W26
sound like the common fl231 fuse problem. consult the fl231 problem article under the tips and tricks section. this is probaly the simplest most inpensive repair on this set
Jan 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need solution
Appreciate the direct "Ask Me".
Your concern with an RCA D52W26 is when you attempt to turn it on, it powers up as indicated by the LED lights but they then power OFF a few seconds later? or it powers on then you get to see bright line(s) left to right, then the TV powers OFF? or it powers on but only bklinking LED lights? If yes on the last any sequence to the flashing/blinking?
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W17 Rear Projection HDTV......No Sound
in the sound settings is the amplifer set to external or internal.
if thats not the problem.. the audio amp chip might be out. to repair this a technician usally replaces what is know as the small signal board.
Jan 10, 2008 | RCA D52W19 52" Rear Projection Television
No sound
do you get sound from other sources? do you have the mute button on?
did you have the cable company look at it?
Jan 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
141 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
