floats sticking keeping it from stopping fuel fill in carb bowl. Result over flow and out ..try opening bottom screw on bottom of carb let fuel flow out than close screw.{located on bottom of carb bowl usually next to a nipple or fuel line} If that don't work tap on side of bowl with something. If that don't work your going to have to remove carb and investigate..good luck..
new carb or plunger assembly diframs not working in carb..problems in carb though. Check for vacuum leaks between engine and carb..intake system..good luck
