Question about HP OfficeJet 6110 All-In-One InkJet Printer
Cannot receve fax
I can send fax but cannot receive.
phone 305.367.4188
Thanks, Adelaide U. Schultze
    Novelist:
    Scholar:
  • 111 Answers
Hi Adelaide,
You probably don't want to publish your number on the Internet since you never know who'll see it and try to spam you one way or another.
As far as your problem goes, HP.com has a web page designed to help troubleshoot fax problems. Here it is:
Fax Troubleshooting
When you click on the link and the web page opens, look in the list of links in the Introduction for one that says "Faxes cannot be received but they can be sent" and click on it. This will take you to the part of the page that directly deals with your problems. Try out the solutions and see if that helps. Post back your results here. Good luck.
Posted on Nov 03, 2008
I CANT RECEVING FAX
1- Have you set the fax machine up to auto receive in the settings and
2- Have you plugged in the Phone line to the machine and made sure that both ends are plugged in the jacks. This is not the network cable but a seperate jack that uses a phone line.
Aug 19, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Brother all in printer, fax problem
Make sure you have a DSL Filter installed on the phone line to prevent DSL signals from interfering with the operation of the fax machine. A DSL filter looks like a line splitter or Y-Adapter and you should have received one or more of them with your DSL modem.
Jan 17, 2008 | Brother Multi-Function Center MFC-240C...
The fax dosn't work,what should I do? I don't have ring tone, and can't receve.
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
May 14, 2012 | Brother MFC 240C All-In-One InkJet Printer
SET UP
CONNECT POWER CODE TO FAX
ALSO CONNECT TELEPHONE LINE TO ITS POSITION.
THEN RESET YOUR FAX TO DEFAULT SETTINGS
SET AUTO RECEVING .
ALSO IF U HAVE PC WITH MODEM U CAN SEND AND RECEIVE FAX FROM IT.
IF U NEEDD ASK ME.
BYE
Mar 24, 2008 | Lexmark X4270 All-In-One InkJet Printer
My fax sound but dont received any fax
hi,
check whether the auto answer is turned on...
either u have the button on the front panel of the printer itself "auto answer" or u will have it in the fax menu...
press the menu button and scroll down to fax setup or advanced fax setup, make sure the auto answer option is turned on....
thanks and regards
agnel
Mar 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Cannot receive fax
1st is the LINE and second is to connect the telephone.
To send and receive fax, u must connect the line into the first jack.
Dec 26, 2007 | HP PSC 2210 All-In-One InkJet Printer
Receving fax
how do you fax a paper off?
Nov 27, 2007 | Lexmark X63 InkJet Printer
Fix the fax
Introduction Review the information below to determine why faxes cannot be sent or received. Review the symptoms below carefully and then select the symptom that best fits your problem. If the solution links you to a different document that does not resolve the problem, return to this document to continue troubleshooting. Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received.
  1. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  2. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  3. If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products.
    1. Visit the HP Support and Drivers Home page .
    2. Select Download drivers and software .
    3. Type in your model number (HP PSC 2210xi for example).
    4. Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models.
    5. On the software download page, select your Windows version.
    6. Locate and select the firmware update.
    7. Follow the directions to download and install the update.
  4. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (bpu04072).
  5. If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (bpu50333) to learn how to correct these problems.
  6. If the problem still exists, continue troubleshooting in the Faxes cannot be sent or received or you're not sure of the problem section below .
Oct 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
50 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
