Question about Pioneer VSX-D412 Receiver
Sub woofer pioneer VSX-D412 5.1
Sub woofer doesn't work but when I touch the cable with the finger listen to a sound
  • 120 Answers
You have a bad cable
Posted on Jan 17, 2009
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
I get no sound out of my sub woofer. I've triple checked the setup for speakers. I've had this unit for years so I'm familiar with the setup. I've taken the speaker to another stereo and it works fine....
check the cable for you sub woofer. If problem exists. Try another cable to verify. What kind of subwoofers are you using? Are you going through the LFE port or are you running speaker wires through the speaker inputs on the sub?
Dec 08, 2010 | Pioneer VSX-D908S Receiver
How do I connect using black and red cables a pioneer VSX-406 sub
Black would be minus - and red would be plus + but this will only work if your receiver actullay has a + and - binding post specifically for the sub woofer. Sometimes you will have wiring binding posts and other times you will have a rca phon plug and maybe your sub has that as well
Dec 04, 2010 | Pioneer VSX-406 Receiver
Sub Woofer works but it won't when hooked up to the receiver
Yes, go to your menu then setup then speakers then subwoofer, it's probably in "LFE" it should give you the option of Sub, LFE, or Both. that should do the trick. Also check the crossover point and season to taste. While your at it; there should also be a setting for speaker level, toggle down to sub and adjust the sub out level, it's probably at it's minimum setting. Hope this helps
Jun 23, 2009 | Pioneer VSX-D409
Sub won't work
if using a sub out cable to a powered sub,you have to go into the reciever menu and turn the sub out on
May 17, 2009 | Pioneer VSX-406 Receiver
Sub woofer
The subwoofer is totally independent from your Pioneer VSX-D412. You can check if it works like you did with a finger on the hot point of the RCA cable (not very good test, as you will hear noise and can't say if that means it works OK) or better connect a known receiver to the speaker connections in the sub and test to see if it’s working properly.
Regarding the receiver, you may not have enabled the VSX to output to the sub. Read the manual on how to check for that. Only Dolby Digital 5.1 signals will allow the sub out, in a receiver of this level. It normally will not let you use the sub in stereo mode. Some more complex units will allow you that, but I believe not this model.
Good luck
Nov 01, 2008 | Pioneer VSX-D412 Receiver
Amatuer needs sub-woofer advice for Pioneer VSX-454...
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Dan
Apr 08, 2008 | Pioneer VSX-454 Receiver
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
Pioneer VSX-D412 Receiver Logo
244 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
