Question about Kenwood KAC-9102D Car Audio Amplifier
Amp runs with no ground
I just bought a new kenwood momoblock class D if that helps,so i hooked up the amp and and it turns on with no ground,i have it fastened to my truck with screws so thats where its getting its ground, but i thought that they were ground protected just wondering if theres a a circit problem ,also the amp cuts in and out once it gets hot i have 4 gauge wire and a cap and it still kills my headlights please help.
    New Friend:
Here's some good info so you will be knocking the spl trophy over. 1 you can go to the car audio shop and drop a fortune or try this which is guaranteed to work.
First get 2 gauge wire then get a super strong battery for under your hood and then by the same super power battery to put back by the amp. I'm an electrician and a bass junkie even longer. So I know this works. Go to you local welding supply store and ask for 2 gauge wire long enough for your vehicle plus 10 feet extra. It is the exact same wire as the wire in car audio shops but higher quality, Its called polyflexoprine. Just doesn't have the colors on it and you will save a lot of money, not to mention this wire has better shielding and more strands per inch, which is good. That should be 40$ Versus hundreds at stereo shop. Next buy two red top batteries. Third replace your battery ground under you hood with 2 gauge ground wire under 9 inches. and put a battery connector for negative side and a copper end fitting from AutoZone on the other end and bolt to chassis remove the original factory ground from under the hood or hook both up at same time doesn't matter. This trick will boost you amp circuit because that's where the circuit ends and most people don't do that . Just doing that can make a huge difference alone in most cases. Next get a 250 amp anl battery fuse along with a one wire in and two wire out rear anl fuse holder for 250 amp distribution for power near your amp at the same time. Get that amp off the wall of the cab you have it mounted on and build an amp rack. Do not mount on box or anything else that vibrates severely. Run your 2 gauge wire ( which can be hard, best to take entire carpet out and you will find pathways to go through and you will never know its there. By the way its Pretty big.) and make you way to the area where you want to locate you amp. ( hint sit amp in car so it sit straight up and you know which wire goes on each side. Biggest mistake made is running rca wires beside power wire. They have to be on opposite sides of the car and know you don't need the expensive one if you follow this golden rule. Before Any further go to the back and find an area that you can nut and bolt a ground down to the vehicle, take a grinder and grind all paint and primer off. Yes its that sensitive,. Place a nut and bolt in best place and try to keep ground well under 13 inches. same for under hood. And fuse under hood needs to be under 9 inches so it cat reweld and fry you amp.
Know that that is done skinning your wire to fit both front and back anl fuse holders. Caution Place rear 250 amp anl before you hook the 2 gauge wire on the the positive terminal wire before you run the power out to the positive terminal. ( fuse before battery or yopu wont get maximum voltage at amp.) of the second battery for you amp in the back. ( This amp is her to serve as a bank of power to be there when the amp unloads. Yes this works. Its easy to built a battery box out of speaker box and paint it and know on will see it and it wont be obvious. (Buy your accessories for this on amazon they have the best to choose from and high quality. Next This is your choice on how you want to ground the rear battery preferably red top. I grounded mine with nut and bot separately. ( You can buy a ground block where you run one wire to chassis as described and has multiple slots on other end, but I recommend again grinding and nut and bolting in different chassis spot to prevent ground looping.
Now with you amp being the big bad boy trim down you 2 gauge or come of the positive rear battery terminal with 4 gauge and run it to the power position on amp. Hook up remote, subs. And for the best performance ground your amp separately and all grounds before and you will get the best results, 4 gauge will be ok . I used the 2 gauge cause my JL 1000 accepted it. If your wont you can use 2 gauge and trim it down and put a connector on it maye...... The only reason you want to stick with 2 gauge is when you put your power meter to you amp to see how many volts are going to the amp and I know your amp will almost double wattage and output if you can get 16 volt or higher than you have an amp at half price cause she doubling what was advertised when you bought it. And I know cause I had one of the 2004 JL1000 and it did the same with the JL 375 x 4 mid amp. And I took every spl contest . hey its about the prettiest install, nicest stuff and I felt like sharing on how to double you power. Amazon has best deals on high end Anl fuse holders for high voltage. And Red Top Batteries will outlast cars I've done it. Good luck boys hope yall have fun and you get this beast of an amp not grounded installed like a pro. I just told ya how.....I'm out Eastwood
Posted on Apr 03, 2014
  • 3 Answers
Try running a ground cable to the batt
Posted on Nov 10, 2007
Ok... well seeing as you're using a 919RMS amplifier D class i'm sure you are having some power drainage problems.. there are a few easy ways to fix this. Look into buying a high output alternator for your car... and also look into have another full battery running for your system.. screw caps they are a waste of money and time.. just buy a battery. Also you should probably be using 0" gauge wiring for your ground and power source... when i had the same amp hooked up i had 0 gauge wiring for power and ground. and for my speaker wire i used 4 gauge... you are using 4 gauge as your power wire? .. also.. what kind of car do you have?
Posted on Dec 07, 2006
    Scholar:
  • 119 Answers
Also if you headlights dim, it is an indication the amp is trying to draw more current than is available. you might have an altinator problem, or may need a bigger one.
Posted on Oct 31, 2006
One thing is take the screws out that you have used to mount it. Obviously you have drilled into bare metal. The path that you have created for the ground was not designed for that kind of current which would explain some of the heat. It warns against doing that in the manual. I have this amp myself and it heats up and cuts out all of the time still. I do not believe it is a power problem. I have a 5 Farad cap. Make sure your main ground for your car has a big enough gauge wire and also, if you can afford it, buy better battery terminals.
Ive just installed two 12in kicker cvr's and i bought the kenwood kac 7205, and ive hooked up everything right and used a digital multimeter to check that the current is coming throught but the amp...
So you check the remote wire to make sure there is 0.5amps running through it, right? Check the fuses of the amp? Checked your ground? Hope this helps
Aug 22, 2011 | Car Audio & Video
Cant get remote wire to turn on amp. it is running from back of kenwood deck to kenwood amp.
OK ! FIRST THINGS FIRST. DID U TEST THE AMP FIST. BEFORE U STARTED INSTALLING RCA CABLES,AND REMOTE WIRES. LETS DO THAT FIRST.GRAB YOUR AMP.SET IT ON YOU WORK BENCH ,TABLE,OR CHAIR.THEN GET (2)PIEACES OF #10 OR #12 WIRE W/1 OF THE WIRES HAVING A 20AMP FUSEABLE LINK ON IT.NOW THE WIRE W/THE FUSEABLE LINK ON IT.CONN THE REMOTE(REM) AND THE 12v + ON THE AMP AND HOOK THEM BOTH TOGETHER ON 1 SIDE OF THAT FUSEABLE LINK WIRE. AND THE OTHER WIRE HOOK IT UP THE - GROUND SIDE OF THE AMP .NOW PICK UP YOUR AMP OPEN UP YOUR HOOD.MAKING SURE THAT NO WIRES OR THE AMP IS TOUCHING THE + 12V OF THE BATTERY. NOW CONN YOUR GROUND TO GROUND AND THE FUSEABLE LINK ON THE +12v SIDE OF THE BATTERY.NOW THE AMP SHOULD HAVE CAME ON. LOOK 4 A SOLID RED LIGHT OR ANY SIGNS OF A SOLID LIGHT THAT HAD CAME ON.
Feb 21, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
Hey i just bought a new pioneer subs 2coils and a kenwood class d 1800 watt how can i connect them to get the clearest sound ?
That amp can run at 1 ohm so if your subs are dual 4ohm then run in parellel. All positives will be conected together and the negetives and then run to the amp.
-please give pos feedback david
Nov 09, 2010 | Pioneer Car Audio & Video
I hooked up my kenwood amp and the power lite doesnt come on kac-6104D
That is because it is in protect mode. A lot of times this is because of a bad ground or the battery is not strong enough and you should give it a charge then try it again. But normally it is the ground and make sure the remote wire has a good connection.
Feb 21, 2010 | Kenwood KAC-6104D D Class Mono Power...
What u think
Hello jayPRICAN,
You do not say what kind of speakers you are running on the amp and that can affect how you troubleshoot the problem.
Most often, a wiring problem such as a faulty ground or short in the speaker wires will cause such a problem. Here are the most likely causes for the amp to go into protection.
1) When a speaker wire is shorted or grounded.
2) Overheated.
3) When a ground wire of the receiver/head unit or the amp itself is not properly grounded.
4) When the amp itself malfunctions and a DC is sent to the speaker output.
First check your power, ground and remote turn-on wires. Then disconnect the inputs and speaker wires. If the amp does not power up normally with all the other wires disconnected, the amp itself is defective. If it does power up with everything else disconnected, reconnect the wires one at a time to determine where the problem is located.
Hope this helps.
Aug 31, 2009 | Kenwood KAC-6104D D Class Mono Power...
Kenwood 1800 class D amp
Try checking the fuse. If no fuse then you probably have some power supply problem. Be sure the ground is well connected to the car also. If all that is fine it sounds like there are some shorted power trasistors. I do amp repair faor a living also I'm the cheapest business youll find. Let me know what you find out. Try disconecting your speakers.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Mar 23, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood 9102d wont power on
YOu might have burned out the inner fuse. Better yet the source connect...
Nov 06, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Humming noise.....
Try to isolate the grounds of the amp and that of your head unit. I mean 'lift' the ground connection. Just connect the hot side and not the ground wire - your amp's grounding and your head unit's grounding might have a voltage loop. smile when the hum dissappears.
Sep 18, 2008 | Kenwood 500W Class D Mono Amplifier with...
Car amp wont turn on
I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jul 29, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Amp won't turn on don't know if amp is fried
Very possible that you have a blown power supply in the amp. If you are running a mono amp then there is a very good chance that you have loaded your amp with too low of a speaker impedence and fried the power supply and maybe the output section of the audio area. Hope this helps.
Mar 30, 2007 | Kenwood KAC-8152D Car Audio Amplifier
Kenwood KAC-9102D Car Audio Amplifier Logo
242 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
