Question about Sony Ericsson P1i
Not powering on
When i power on my p1i its keyboard flashes 10-10 seconds and wont starts up
  • 113 Answers
Hold the the *c and start button and take the battery out and replace it in if still its not starting up no other go needed to take to the doc ie service  centre as the ic is faulty as my friend had the probs
Posted on Nov 01, 2008
Pcg-61211m wont turn on and the power button starts flashing
some time the cpu enter C1 or c3 or c5 status for power saving try to unattached the battery , wait 10 sec, and try to power up without battery,if not solve try holding and pressing power button more than 4 second, if problem persist may be you have some problem with your hardware or may be your power adaptor does not meet the minimum require wattage
best regards
Dec 14, 2013 | Computers & Internet
Dead P1i; wont power up; wont charge
the bios might need to be flashed. . have it flashed or reformatted by a technician
Feb 16, 2010 | Sony Ericsson P1i
T2042 E-Machine Both the power button and the hard drive light keep flashing i also noticed the lights also flash they all flash fast but never boots. The power button is flashing green along with green...
Disconnect the power cord from the back of the system. Press and hold down the power button for 10 seconds.
Disconnect everything from the back of the computer ,except keyboard, mouse and monitor.
Reconnect the power cord and then check
Thanks for using fixya
proton
Nov 07, 2009 | E-Machines eMachines Desktop PC
SE P1i doesnt switch on
Try cleaning the battery terminals. You may have corrupted your phone's software. Try flashing it once. Flashing may cost arounf 7-10$
Jun 21, 2009 | Sony Ericsson P1i
Power LED Flashing Yellow on Qosmio laptop F15
This flashing LED means only one thing, and it is quite harmless:
Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba power led flashing yellow
This flashing LED usually means only two things, both are quite harmless:
1. Some laptops will flash the power LED when battery is charging. If this is the case, it should stop when battery is fully charged. This can be presumed if the laptop starts normally while LED flashes. If not, suspect step 2 below:
2. Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
good luck.
Power serge
ok First question does the led continue to blink after 70 seconds after u plug it in. it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature. Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set
Jan 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Keyboard randomly stops working
If this only occurs on battery power and your battery only holds a 10 minute charge? And your keyboard is external (PS2, or USB) it draws power from that battery (even the OEM keyboard does) and is probably glitching on you for lack of power. That's of course if I have understood you correctly?
Good luck.
Jan 12, 2008 | Sharp Actius AL27 Notebook
Sony Ericsson P1i Logo
98 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
