Question about ECHO, Inc. PB-251C Handheld Blower
Echco PB-230LN blower
Runs but doesn't seem to have any power.......seems to be running too rich and I have replaced spark plug and fuel filter........HELP!!! Thanks
  • 1 more comment
  • agcjoe Nov 10, 2008
    I have a similar problem. My Echo blower worked great for the first 3 years. Iit has not been running good for the last year. But it still works OK, but not great. I recently replaced the spark plug, air filter, and fuel filter. It still is not running good. Any help will be greatly appreciated.
  • Anonymous Nov 17, 2008
    I have the same problem...Will try the seafoam and report back
  • Anonymous Mar 16, 2014
    Blower starts and runs for awhile. However, it then loses power and eventually stops. It will start again, only to stop. It will start each time, but then cuts off
Try adding some "Seafoam" brand additive to the fuel mixture, that did the trick for mine. Must have been something in the carb and the Seafoam cleaned it out, runs just like the day it came out of the box
Posted on Nov 12, 2008
Echo PB-251. Wont run full speed,changed ,plug,filters
I'm 99.9% sure it's the fuel line. The ethnoll in gas really shrinks the oem fuel lines
Jan 13, 2015 | Echo Pb-251 Leaf Blowers
My echo backpack leaf blower pull start seems stuck it wont crank
Without getting to involved with it, did you always mix the correct fuel/oil ratio? or has someone else possibly put straight gas in it without oil? Another possibility is that the recoil could be broke. I would try to determine if the piston is seized in the cylinder. First remove the spark plug and try to pull the starter rope while listening closely for any strange noises from the engine. If it pulls fine then, replace the spark plug and try to start it again. If that doesn't work then I would remove the back cover and remove the muffler so you can look at the cylinder. You will need a phillips screwdriver and a set of metric allen wrenches. Hope that helps.
Aug 30, 2011 | Echo Pb - 413t Backpack Blower
I have an older echo blower. just had it tuned up and adjusted and still running poorly. just wondering if it is my fuel mixture of 25;1
25:1 may be too rich a mixture. Clean your spark plug well. Then get some good synthetic 2 stroke oil and try a 32:1 mix or a 40:1 mixture. Here is a fuel mix chart for you use.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
May 15, 2011 | ECHO, Inc. PB-251C Handheld Blower
I bought a new echp pb-251 blower last year. towards the end of last season the blower seemed to run sluggish. I attributed it to the cold weather and stored it properly with fuel stabilizer. Now here in...
Hi, there is a wire screen in the exhaust outlet that blocks up with carbon deposits. It can be removed and cleaned with a wire brush. If blocked it will give you the problem you have and also make the blower quieter than it should be. Regards Phil.
May 01, 2011 | ECHO, Inc. PB-251C Handheld Blower
My Echo Leaf Blower (PB-251) will not run at high speed. It is running to rich. Help please. Charlie
I've been fighting with an Echo PB-251 blower and an Echo SRM-225 string trimmer since near the end of last lawn season (this is the forth season I've had them). Along comes a thread on a firearms forum and lo and behold the answer to the problem is spelled out in terms even I can understand.
After reading that thread (which attributes the problem of the engine bogging down when throttle is activated to collapsing fuel lines) I was going to just replace the fuel lines, but I discovered that there are kits that include new fuel lines, rubber grommets, filters, clips and cap seals for about $13.00 each. Hell, the kit for the SRM-225 even provided a new primer bulb. Ten minutes after the UPS truck delivered them to my door I had both machines running like new again. If you've tried other things and it still hasn't worked I highly suggest you try this.
Jan 05, 2011 | ECHO, Inc. PB-251C Handheld Blower
Blower not running at high rpm when full throttle. Cleaned air filter, gas vent, gas filter and spark plug. Blower is 3 years old. Have not bought any new replacement parts.
Try removing the muffler and look inside of the exaust port, you should be able to see the piston in the full opening of the port. If you can, try starting and running at wide open throttle. If it runs fine( a bit loud, so wear hering protection), then you have a plugged or partialy blocked muffler or spark arestor. Sometimes rich mixture can cause excessive carbon build up.
Hope this was helpfull.
Nov 07, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Jul 17, 2009 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
ECHO, Inc. PB-251C Handheld Blower Logo
676 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
