Question about Kenwood KDC-119 CD Player
Bad radio reception
Just bought a 1997 Malibu and the car stereo has bad reception over the radio. I was thinking maybe the stereo is not connected to the antenna properly. So how do I check this out and rewire?
Problem: Radio Reception is bad to non-existant. AM is usually worse than FM.
Reason: Antenna connector has come loose, and needs to be reconnected. This happens when a passenger pushes the carpet toward the firewall and disconnects the plug.
Affected Model Years: 1997, 1998, 1999, 2000, 2001, 2002, 2003
Permanent Fix:
1. First check to make sure the antenna at the back of the radio has not come loose.
2. Remove the plastic cover on the front passenger door threshold held in place by three pressure clips.
3. Peel back the carpet on the front seat passenger floor.
4. Locate the coax antenna cable running along the side.
5. Reconnect the two pieces of antenna that have come loose.
6. Roll the carpet back, and re-install the threshold cover.
Posted on Jun 30, 2009
Avalon radio
I would check the connections on the grid, if they are ok you have to live with yagi effect.
Mar 25, 2014 | 2000 Toyota Avalon
Antenna removal
Poor reception is ant. No reception is radio. Poor explanation gets poor answer
Mar 12, 2014 | 1991 Chevrolet C1500
96 Marquis LS Poor am radio reception
Do you have the BLUE power antenna wire hooked up?
If not it may help your issue
Jun 12, 2013 | Alpine Wire Harness Ida-x305 Ida-x303...
My reception on my radio is get weeker every day i have lost all am reception ?
Hi, Check the antenna and the connection on the radio. you will have to remove the radio to check there. Replace the antenna
Jun 27, 2011 | 2004 Volkswagen Jetta
How do I fix the entire antenna connection (cables, etc.) on a 2001 Volkswagen Jetta? I have a 2001 Volkswagen Jetta, and when I bought the vehicle (used) it did not have an antenna. I recently purchased...
the radio could be bad as well. if the tuner in the radio is bad it wont get reception either. go with a good aftermarket one not a cheapy there no good anyway.
Apr 22, 2010 | 2001 Volkswagen Jetta TDI
I have replaced the car radio antenna on 1993 Discovery. Works fine on am very pore reception on fm. The car radio, factory fitted, is Eurovox Model 92039986. Is there an adjustment to tune the radio to...
Check your connections on the antenna again. Am usually gets decent reception. sounds like your antenna connection isnt fully connected either at the stereo connection or at the actual antenna connection.
Mar 29, 2010 | Car Audio & Video
Bad radio reception
u don't need a wireing diagram check the wire that runs from the antena to the stereo and the connections. usally the connection to the antena gets corrsion in it. so just clean up the connections
Aug 12, 2009 | 1997 Audi A6
No AM reception for car radio...do get FM reception.
I was having the same problem with a jvc kd hdr 30. I Installed it myself over a year ago and never wanted to deal with the issue. Finally, I decided to take a look at it today.
On my head unit, all wires were connected except one blue one with a tag that says "do not connect to power, for remote device or power antenna only." This unit is in a '97' MBZ E320 with no visible antenna; I think it is part of the windshield. In any case, between the wiring diagram in the manual and the harness that is part of my car, I was left with 2 blue wires to choose from, one with a white stripe and one with a gray stripe. After testing both for power or ground, I determined neither had power with key on or off. Both had high resistance ground when compared to the chassis ground. In other words, I measured between chassis and these wires. First, I took a wire and connected it to the chassis ground and connected the other end to the blue wire coming from the unit while tuned to a local am station. This simply killed all reception am or fm but did not harm the unit. Next, I connected the blue wire with gray stripe of the car harness to the blue wire of the unit and again this killed all reception. Then I connected the blue wire with white stripe of car harness to the blue wire of unit and presto magic I had great am reception.
I am guessing that this blue wire with white stripe must be part of the antenna itself or perhaps is a connection that increases antenna power. Maybe 'power antenna' on tag refers to an actual powered antenna (like as in amplified?) and not as in an antenna that rises up out of fender, as I believed.
This may not help the first person with the question, but maybe it will help someone out there who searches for these kinds of answers like I do from time to time.
May 31, 2009 | JVC KD-PDR30 Car CD/ MP3 Player
Radio Problem
There is not an easy answer for this one. Some troubleshooting needs to be done. I have seen the Rockford Fosgate system in many of the newer Sentra's. Try hooking a known working speaker to a nonworking position. This will tell if it is a speaker problem. If the problem persists, this could be stereo or amplifier.
Terrible reception troubleshooting, a bad antenna will give poor FM and no AM. If both have bad reception, this is a stereo problem. You can remove the stereo from the dash, place a small pick tool or screwdriver into the antenna jack and test reception. If the reception problem clears, this is a antenna problem. I have seen car detailers pull the connector from the rear window antenna and forget to plug it back in too.
Nov 10, 2008 | Car Audio & Video
No antenna, no radio reception
If the model number is SC-AK630, please confirm. The antenna should still be available from any Panasonic part distributor. Please confirm the model and I'll get you the part number and cost.
Dan
Jul 29, 2008 | Panasonic SC-AK630 CD Shelf System
Kenwood KDC-119 CD Player Logo
465 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
