Question about Wharfedale DVD-M3 DVD Player
WharfedaleDVDRHD400F After working perfectly since new, my WharefdaleDVDRHD400F seems to have `died`! The Standby light is on but no other lights or the display panel are active. Nothing on the remote or front panel works. (it was purchased from Argos approx. 18 months ago) I have tried `re-booting` by unplugging & turning back on again but this does not work Any ideas? Thanks Neil
  • neil147 Nov 03, 2008
    Thanks Ekse,
    The StandBy light is on - so it`s not the fuse in the plug. Is there one in the machine? I can`t see reference to one in the `User Manual`
  • Wharfedale Master
  • 19,396 Answers
Yes there is also a fuse inside the machine, and it is located in the power supply area of the internal board.
However when the power supply fuse blows, you get no power at all.
In your case the unit is in standby, then the problem is clearly not the fuse, when the fuse has blown you just get no power.
I have seen that you already unplugged the unit, but I suggest doing another attempt and leaving it unplugged for a couple of hours, if you have not done this already.
If the unit is properly starting up, but get stuck with a message on display check that there is no disk inside. In case press repeatedly the eject button while you start the machine to get hold of the disk.
Here is also a factory reset :
  • Unplug power.
  • Hold down the power button (some models you need to hold the play) while at the same time you connect back the power cable.
Be aware of the hazard involved in the operation while you do this.
If all the above did not work, then the unit is in protect mode, probably because a capacitor has blown or some other component is faulty.
In this case the DVD must be inspected by a technician.
In this case I suggest contacting Argos and asking them the cost of an extended guaranty on this item, it may still be worth repairing.
Posted on Nov 03, 2008
    Genius:
  • 1,550 Answers
It sounds like you got the power surge problem .
It could be as simple as a bad regulator transistor or IC.
  • 10,594 Answers
Please check its power supply board and look for open fuse in secondary voltage area like +5V or +9V like that.
  • Wharfedale Master
  • 13,433 Answers
Check the fuse, it may have blown due to a power surge, thats a cheap thing to replace few $ if its the problem.
  • Ekse Nov 03, 2008
    If your device is out of warranty, do open it and check the fuse in the powersupply area, ive seen this one before, and in that case, it was a diffrent brand most likely but replacing the fuse solved the problem. You ain't got noting to loose if your outside warranty.
Flatron l1932p
Power supply may have failed
Nov 30, 2017 | Computers & Internet
My Denon AVR-75 seems to stay in standby (red standby light is on) and I don'd get surround sound through it. How do I get it out of standby?
if the receiver does not power on from standby there is a problem like bad power supply or even bad macroprocessor. You need to bring it to a service center for diagnosing. 10-years old receiver, maybe better to buy new one.
Nov 23, 2011 | Denon AVR-75
The standby light is flashing, can't get tv to turn on. FLashes 9 times
Hey there, I had the same problem back in mid-2010 Seemed that the circuit board died. They had to change the whole board just because 1 circuit died which failed to connect to the LCD.
So once they changed it, it was only about $130. The TV worked as good as new.
Let me know if you need anymore assitance!
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial}
Thank you for using FixYa!
I hope that I helped you & that this post is helpful to you at most!
Don't forget to rate! :)
Jan 15, 2011 | Sony KP-57WS520 57" Rear Projection...
Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
May 14, 2010 | Haier HLH406BB 40 in. LCD HDTV
My samsung dlp hl-s5686w turns for a minute video disappears audio continues and three lights flash the standby/temp,timer,lamp. all at the same time.
I'm having the same problem. Tried several things from dusting the inside with an air blower, removing the bulb and putting it back in, making sure the side panel is installed correctly and none of this has kept it from shutting off. Samsung's site says the three lights flashing means replace the bulb but I'm not buying it. My picture looks perfect....jsut that the TV keeps turning off. It all seems like a heating problem but my fans are still working. I'm scratching my head thinking what to try before forking out $150 for a new bulb.
Apr 30, 2010 | Samsung HL-S5686W 56" HDTV
Flashing Standby Light - Sony 40 in Bravia
Similar problem. Unplug for 36 hours solved the problem.
Aug 23, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sometimes tv won't turn on and standby light blinks and sometimes it works perfect
The key here is the number of blinks of the standby light. This is an internal diagnostic code. Please provvide that count and I should be able to suggest possible fixes.
Thanks,
Dan
Apr 26, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Light always ON!!!
hold the button and wait till the light blinks twice and it will turn off
Jan 29, 2008 | Motorola Mobility HS820 Consumer Headset
Wharfedale DVD-M3 DVD Player Logo
50 people viewed this question
Top Wharfedale Televison & Video Experts
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
