Question about The Times Case Corporation Tractors International Harvestor
Case international jx 75 tractor
How do i replace the heater hoses on a case international jx75 tractor with cab
How do I replace the drive belt on a Deere Jx75 mower?
with much frustration and pain .too complicated to explain here
Sep 30, 2016 | Garden
How do I remove and replace the drive belt on my JX75 Deere mower
Here's a link showing you how to change your drive belt.
John deere jx 75 lawnmower wont start
does it crank no start
or
no crank at all ???
big difference
Oct 19, 2014 | Garden
Heater hose diagrams
The interior cab heating system is identical to 4-wheeler cars. Two hoses connect to the cab heater core box, which is part of the engine radiator coolant system. If you're not getting heat when you turn on the heater fan, then one of the hoses is blocked or the heater core box is blocked up. One hose is inlet, which brings hot coolant from the engine to the cab heater core box. The 2nd hose is outlet which returns the coolant fluid from the heater core box back to the engine coolant system. Its likely these hoses and the heater core box are 20 years old and had never been replaced since the semi truck rolled off the assembly line in 1994. To diagnose for blockage, disconnect both hoses from the engine side, then connect an air blower to one hose to push pressurized air into this hose. Air should be coming out the other hose. If there's no air, or less air pressure, then there's blockage which is restricting hot coolant from passing through, resulting in little or no hot air when you turn on the "hot" air fan. Replace the heater core box first. If you're not getting hot air, then replace both hoses next.
Nov 18, 2013 | 1994 - 1996 Peterbilt 200-33 Engine...
Where is the block heater on a 580 case
my 580b case didnt have a block heater. i purchase a new one from my local dealer and the instruction tell me to mount it in the block on the drivers side. in behind the fuel filters are 2 plugs...or in my case 2 nipples because mine had a cab heater hooked up..it says to use the rear most port
Feb 26, 2012 | Ertl 580 Super M Series II Tractor
Does any one know where i can get an operators manual fro Case JX 75
I would go on line to CASE customer service and see if one is available and from where
Aug 31, 2011 | Milwaukee Tool Case Heat Gun
Is the heater core on a 1981 bronco in the engine compartment or the cab compartment
in the cab, but procedures are different depending on whether or not you have A/C. See below
1980-81 Comfort Vent Heaters, Without Air Conditioning
  1. Disconnect the heater hoses from the heater core tubes and plug the hoses with suitable 5 / 8 inch; (16mm) plugs.
  2. Remove the glove compartment liner.
  3. Remove two (2) spring clips attaching the heater core cover to the plenum along the top edge of the heater core cover.
  4. Remove eight (8) screws attaching the heater core cover to the plenum and remove the cover.
  5. Remove the heater core from the plenum taking care not to spill coolant from the core.
To install:
  1. Install the heater core in the plenum.
  2. Install the heater core cover (eight (8) screws and two (2) spring clips along the top edge of the cover).
  3. Install the glove compartment liner.
  4. Connect the heater hoses to the heater core. Tighten the hose clamps.
  5. Add coolant to raise the coolant level to specification.
  6. Check the system for proper operation and for coolant leaks.
1980-81 Standard & High Output Heaters, Without Air Conditioning
  1. Disconnect the temperature cable from the temperature blend door and the mounting bracket on top of the heater case.
  2. Disconnect the wires from the blower motor resistor and the blower motor.
  3. Disconnect the heater hoses from the heater core and plug the hoses with suitable 5 / 8 inch; (16mm) plugs.
  4. Working under the instrument panel, remove two (2) nuts retaining the left end of the heater case and the right end of the plenum to the dash panel.
  5. In the engine compartment, remove one (1) screw attaching the top center of the heater case to the dash panel.
  6. Remove two (2) screws attaching the right end of the heater case to the dash panel, and remove the heater case from the vehicle.
  7. Remove nine (9) screws and one (1) bolt and nut attaching the heater housing plate to the heater case, and remove the heater housing plate.
  8. Remove three (3) screws attaching the heater core frame to the heater case and remove the frame.
  9. Remove the heater core and seal from the heater case.
To install:
  1. Position the heater core and seal in the heater case.
  2. Install the heater core frame (3 screws).
  3. Position the heater housing plate on the heater case and install the nine (9) screws and one (1) bolt and nut.
  4. Position the heater case to the dash panel and install the three (3) attaching screws.
  5. Working in the passenger compartment, install two (2) nuts to retain the heater case and plenum right end to the dash panel.
  6. Connect the heater hoses to the heater core. Tighten the hose clamps.
  7. Connect the wires to the blower motor resistor assembly.
  8. Connect the blower motor wires.
  9. Position (slide) the self-adjusting clip on the temperature cable to a position approximately one 1 inch; (25.4mm) from the cable end loop.
  10. Snap the temperature cable on the cable mounting bracket of the heater case. Then, position the self-adjusting clip on the door crank arm.
  11. Adjust the temperature cable.
  12. Check the system for proper operation.
Oct 05, 2010 | 1981 Ford Bronco
Are enclosed cabs available for a 1985 model 1050? It is two wheel drive and has a #75 loader installed. There is no ROPS on this tractor.
I have never seen a 1050 with a cab other than homemade ones but if anyone makes one it would be Lauren Cabs.Try googling them for a dealer near you that you can call,it's worth a shot.
Dec 22, 2009 | John Deere Tractor Side Screen...
The Times Case Corporation Tractors International Harvestor Logo
298 people viewed this question
Top The Times Toys Experts
Andrew Taylor
Andrew Taylor
Are you a The Times Toy Expert? Answer questions, earn points and help others
