Question about Pioneer DEH-8000R CD Changer
Grille I am trying to replace the grille on my dehp 8000r. I have done it before but I can't remeber how I did it. Please help!!!
  • 199 Answers
The grille. do you mean the trim around the radio, or the panel? regards Mark www.carradiospares.co.uk
Posted on May 03, 2007
Need replacement grille for Dimplex floor drop-in heater FFIH15A31
Get the dimensions of grille and contact dimplex, or plumbing & heating supply store for new grille.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Apr 15, 2014 | Dimplex FFIH15A31 Electric Heater
Need to re paint my grille
automotive paints require a good clean and well prepared surface like light waterpaper sanding to remove any oily or fatty resedu and the correct undercoat before applying a new coatings otherwise it will not last chipping or peeling will occur.
May 06, 2013 | Cars & Trucks
Nothing fits as it should, I would like to find a step by step install vidio for a part number 71405 shadow billet grill by putco. thanks mb
Congratulations on your purchase of a high quality PUTCO product. Should you need any application or technical assistance feel free to call us at: 1-800-247-3974 Monday-Friday 8:00 a.m.- 5:00 p.m. (Central Standard Time) Contact your PUTCO dealer for other quality accessories. PUTCO Inc. - 216 West First Street - Story City, Iowa 50248 PLEASE READ ALL INSTRUCTIONS BEFORE INSTALLATION AND TO CHECK TO SEE THAT ALL PARTS ARE INCLUDED. Please consult your Vehicles owners manual for vehicle air flow restrictions Putco is not liable for any vehicle damage resulting from the installation of our Grille inserts (71101) 99-02 CHEVROLET SILVERADO / 00-06 TAHOE/SUBURBAN, (71107) 01-02 CHEVROLET HEAVY DUTY, (71102) 99-02 GMC SIERRA/YUKON, (71102) 01-02 GMC HEAVY DUTY, (71104) 99-03 FORD F-150 (71137) 03-06 CHEVROLET HEAVY/LIGHT DUTY, (71138) 03-06 GMC HEAVY/LIGHT DUTY, (71189) 07-UP CHEVROLET LIGHT DUTY, (71163) 07-UP CHEVROLET HEAVY DUTY, (71158) 07-UP TAHOE/SUBURBAN/AVALANCHE, (71190) 07-UP GMC SIERRA LIGHT DUTY, (71164) 07-UP GMC SIERRA HEAVY DUTY, (71159) 07-UP GMC YUKON/YUKON XL. Step 1: Remove the factory plastic hood that covers the area between the grille and radiator by removing the plastic plugs or screws that fasten it in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 3: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 4: Reach between the grille and radiator and reinstall the bolts, plates and nuts onto the grille insert. Step 5: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71105) 99-07 FORD SUPER DUTY PICKUP AND 00-05 FORD EXCURSION, (74105) HORIZONTAL SIDE VENTS Step 1: Remove the four factory screws that hole the top of the factory grille in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 4: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. If you have purchased the side vent pieces install them at this time. NOTE: The installation bolt will go though a hole in the side vent that is closest to the center grille section. Step 5: Carefully pull the grille forward and reach between the grille and radiator, install the bolts and mounting brackets onto the grille insert and/or the flat washer and nut on the side vent pieces. Step 6: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71103) 94-01 DODGE RAM, (71132) 02-05 DODGE RAM, (71156) 06-08 DODGE RAM, 04-UP FORD F150 AND 08- UP FORD SUPER DUTY Step 1: Remove the bolts and mounting plates from the bag kit. Step 2: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 3: Reinstall the plates and nuts onto the grille insert. (Verify that the bolts do not come into contact with the radiator) Step 4: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. Note: Please adjust horizontal blades if irregular. This is the result of shipping and handling outside of Putco's contro
This is the installation instruction sheet for your grill.
Apr 16, 2011 | Ford F-250 Cars & Trucks
How do you take the grille off of a 1996 isuzu trooper 2
Trooper
See Figures 3, 4 and 5
Fig. 3: Front grille assembly-1984-94 Trooper
Fig. 4: Front grille assembly-1995-96 Trooper
Fig. 5: Retainer clip used to secure the front grille
  1. Raise the hood and support it with the prop rod.
  2. On 1981-94 models, remove the retainer screws from around each headlight.
  3. Remove the retainer screws from the corners and center of the grille.
  4. Using a small prytool to press the tab on each of the grille retainer clips at the top of the grille upward while pulling the grille away from the radiator support.
  5. When all the tabs have been released, lift the grille up slightly and out to remove.
To install:
  1. Engage the lower portion of the grille into the radiator support.
  2. Carefully push the grille toward the radiator support, making sure the retainer clips align with their respective mounting hole. Once all the holes align, press the grille and retainer in until it clicks into position.
  3. Install the retainer screws from the corners and center of the grille.
  4. On 1981-94 models, install the retainer screws around the headlight.
Hope helps (remember rated this).
Jul 09, 2010 | 1996 Isuzu Trooper
Front grille replacement
The grille in the WJ models is incorporated into the fascia. To replace or service the grille, the fascia must be removed. The grille is equippedwith an insert which can be serviced.
For other details and graphic guide, can check the Service Manual Section-23-Body-ewj23S (page 28 and next).
I really hope helps with this (remember rated this hep) Good luck.
Dec 15, 2009 | 1999 Jeep Grand Cherokee
How do I replace the grill on my 1990 Pontiac Grand Am
1989-91 GRAND AM
Fig.: When installing the grille, snap the retainer tabs into the slots in the mounting panel, inserting the bottom tabs first
To remove grille, just release the tabs and pull grille the outward. Installation is done by inserting grille and locking the retaining tabs.
  1. Unfasten the screws along the top of the grille.
  2. For Achievas, unfasten the retainers from the bottom of the grille.
  3. Pull out on the grille to release the lower tabs.
  4. Installation is the reverse of the removal procedure.
Hope helped (remember rated this help) Good luck.
Nov 02, 2009 | 1990 Pontiac Grand Am
Remove the grill on 1989 chevy truck
PLEASE DON'T FORGET TO RATE!!!
Removal & Installation
  1. Remove the parking lamps and side marker lamps.
Grille mounting-except 1988-91 R/V Series
  1. Remove the 2 grille-to-latch support bolts.
  2. Remove the 1 grille bracket-to-latch support bolt.
  3. Remove the 6 grille-to-radiator support bolts.
  4. Lift the grille and filler panels from the truck.
  5. Install the grille
Nov 01, 2009 | 1999 Chevrolet Silverado 1500
Parts missing
The grill is held on in place by the two springs pushing on to it from the grill pannel it sits in.
Sep 23, 2009 | 1990 Lincoln Town Car
Pioneer DEH-8000R CD Changer Logo
37 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
