Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Have to hand start the last spin cycle
Every cycle works but the last spin. can hand start it close the lid and it finishes no probs. if it was coupler, agitator also woudn't work correct? and if it is the timer is it possible for every other cycle to still function
  • bryan gurr Nov 03, 2008
    i havn't taken the motor out yet but now both spin cycles have to be hand started would it still be the carbon brushes
  • 94 Answers
Sounds like carbon brushes in the motor are not making perfect contact,take out inspect,clean or replace clean up commutator
Posted on Nov 01, 2008
The drain pump is running before I start a cycle
A very simple answer is that maybe the last cycle never finished, give it a chance to finish (a few minutes, with the lid closed) and see if that works.
Dec 14, 2014 | Washing Machines
The machine does not perform last spin cycle
check lid..either the lid switch is bad or the lid switch actuator which is made into top...when in final spin push down on the right hand top part of lid,,,if it starts replace part needed,,,good luck
Sep 12, 2011 | Avanti Top Load Washer W797
Washing machine will not go into the spin cycle - it stalls at the end of the wash cycle leaving the clothes soaking in a tub full of water i tried to restart at the rinse cycle and it stalls after the...
This is usually caused by a bad lid switch. Whirlpools are known for lid switch issues. If the lid switch is not telling it that the lid is closed, it will not spin. Look where the lid switch is and press on the lid directly above it -- it may start. This will prove it. You can find an exploded view (and get the part) at www.appliancepartspros.com
Feb 14, 2011 | Whirlpool Washing Machines
CYCLE WILL NOT COMPLETE
Hi
This would be due to the lid switch, the machine is designed that it will only spin and drain with the lid closed, if the lid switch goes bad the machine thinks the lid is open. Here is a link to a video that shows how to replace the switch.
Lid Switch
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle is not working on my GE profile washing machine
lift the lid unplug the unti for 60 seconds plug in close the lid 5 time in 10 seconds
Apr 20, 2010 | Washing Machines
Heller awm600 washing machine e2 error on spin cycle. Washes ok but does not spin properly and gives e2 erro, will not continue with cycle. Any suggestions? Thanks kayjay
BROKEN PIECE OF PLASTIC ON LID CAUSING MACHINE TO THINK LID IS OPEN ALL THE TIME. REMOVE LID, WEDGE BROKEN UP SATAY STICK INTO GAP, REPACE LID AND VOILA!! WASHING MACHINE SPINS AND ALL FOR LESS THAN 15 MINUTES WORK AND A STICK!
Jan 09, 2010 | Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
LWH0050P Stackable Compact Washer not spinning
sounds like it could be the transmission. Does the tub turn when you turn the pulley in either direction with your hand? And take the belt off see if the motor turns when you close the lid and turn it on without the belt??
Aug 30, 2008 | Washing Machines
Kenmore model #110.22802100 drains but no spin
If it is draining, then the motor is ok.
If it is agitating properly, then the motor coupler is ok.
This leaves the gearcase, clutch, basketdrive(brake), basket drive block, or timer.
Raise the lid and hold the lid switch down. Start a rinse cycle and let it go through the cycle. It should drain the water, then stop the motor for a split second then kick the motor back in and start spinning. If it doesn't drop out that split second then the timer is holding it in neutral drain. You can recreate this by letting it start draining, then let off the lid switch, then depressing it again. The basket should start spinning. If not,
Raise the lid and hold the lid switch closed. Start it in spin and see if you can get it started spinning by hand. If so you probably have a slipping clutch.
Post back with any questions.
You can go to sears.com, click on parts, and enter your model number and see parts diagrams of the washer. This can be helpful.
Nov 25, 2007 | Zanussi F1045W Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal De
