Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Nut holding fan
What is the trick to removing it
  • isadaqueen Nov 08, 2008
    Pull cord came off. I'm trying to remove the fan so that I can re-tie the pull cord.
  • toby181 May 08, 2009
    Removing the nut holding the fan on a Weedeater Featherlite FL 1500i
  • 62 Answers
Hummmm......Not sure. What have you tried? Is it backwards threaded? Why are you removing it?
Posted on Nov 01, 2008
Removing water pump clutch
You need to rent/borrow a fan clutch wrench remover set. They are large skinny wrenches that hold the bolts on the fan so it doesn't spin, while loosening that large nut. Sometimes you can monkey around with strap wrenches and crecent wrenches, but thats no fun. Kragen/Oriely's rents the tool for a $89 deposite. Return when done, and you claim back all your money. Yay! free toolls.
Oct 08, 2012 | 2000 Buick LeSabre
Is the big nut holding the fan to the clutch right hand, (right to tighten,left to loosen)? 1993 navajo
You mean standard or reverse thread?
Usually crank nuts are reverse thread in relation to the direction of the pulley.
So if the pulley\engine spins clockwise then the nut is probably going to loosen by spinning it counterclockwise.
Afterall it would do no good to go down the road and have the rotation of the engine spin the nut off of the crank pulley eh?
Feb 03, 2012 | 1993 Mazda Navajo
to remove clutch fan you need to remove upper fan shroud, you need large wrench to remove the fan clutch retaining nut to remove fan and clutch away from the engine drive belt should keep pulley from turning while loosen fan clutch retaining nut.if pulley belt turns while loosen fan clutch bolt remove drive belt use strap wrench hold pulley while you remove fan clutch bolt this procedure for checvrolet if you working on volkswagon you need spanner wrench hold the idler pulley while you use large wrench to loosen the large drive nut to fan clutch. you have to remove fan with clutch from engine then you can remove clutch from fan you can go to auto parts stores rent a spanner wrench try auto zone they rent out tools.
Jan 05, 2012 | Cars & Trucks
In changing the water pump I cant get the fan removed or that nut to budge is there a trick to getting it off
I cant say for sure with your vehicle but with some require a puller to get them off. as far as the nut goes they usually have reversed threads on them? if thats not the problem try some pbblaster or something sometimes they just get seized up.
Mar 06, 2011 | 1999 GMC Jimmy
Can't pull the radiator uot of my 1999 BMW 528i, t...
You gotta remove the fan and shround. Fan nut is 1.250" wrench. Fan nut is left handed thread. this means rightey loosey, lefty tightey. Go get the special tool to hold the fan pulley bolt heads. While you are turning the fan nut clockwise to loosen the special tool holds two of the fan pulley bolt heads to keep the fan pulley still. And voila, off comes the fan. then you can remove the shroud with it. Then you can remove the radiator. Fun job. I've got it down to 8 minutes.
May 19, 2010 | 1999 BMW 5 Series
I can't remove nut from end of vacuum.
The nut is reverse threaded . If you hold the fan with one hand use a ratchet to loosen the nut, you will have good enough leverage to break it, but if you don't then here's a little trick....Take your vise grip pliers and clamp it to the belt end shft of the motor. Now with your worktable (or floor) brace the vise gripped motor shaft . with the ratchet, turn the nut to the right. Like you're tightening it. this should be sufficient enough torque to bust that nut. I hope I was able to help you , let me know. Thanks, Rene (the Vacuum Doctor)
Nov 12, 2009 | Vacuums
Water pump replacement - how involved is replacing the water pump
The waterpump on a chevy suburban can be removed once you remove the radiator fan.
  1. Drain the coolant from the system.
  2. Here is a way to remove the fan clutch withouy a fan clutch tool. The trick is to leave the belt on and tight.
  3. Take a 1 7/16 inch wrench and put it behind the fan onto the big shaft nut attaching the fan to the water pump. P
  4. ut it straight up and crack it counterclockwise with a hammer.
  5. This should loosen the nut.
  6. After that just spin the fan off and the rest is easy.
  7. Make sure you clean the old seal off of the engine. It is small and easy to miss.
  8. remove the serpentine belt.
  9. remove the hoses connecting to the water pump
  10. remove 4 bolts holding the water pump onto the block
  11. clean the block of any old gasket
  12. fit the new waterpump and new gasket.
  13. connect the hoses to the pump.
  14. refit the serpentine belt
  15. refit the fan
  16. refit the rad and cowling
  17. fill it up with coolant.
  18. Run the engine and check for leaks.
Oct 03, 2009 | 2002 Chevrolet Suburban
Need to take off fan clutch, have taken off parts in the way
4.9L SFI
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Fan Clutch Holding Tool T84T-6312-C Fan Clutch Nut Wrench T93T-6312-B
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The large clutch assembly nut has a right-hand thread and must be rotated counterclockwise to remove it.
    Remove the fan clutch (8A616) from the water pump (8501) by turning the large nut, which is part of the fan clutch, using Fan Clutch Holding Tool T84T-6312-C and Fan Clutch Nut Wrench T93T-6312-B.
  1. Remove two screws retaining fan shroud.
  1. Remove the fan blade (8600), fan clutch and shroud.
  1. If the fan blade and fan clutch have to be separated, remove the remaining bolts attaching the fan blade to the fan clutch
5.0L, 5.8L and 7.5L Engines
  1. Remove screws retaining fan shroud (8146) to radiator (8005).
  1. Remove four screws retaining clutch on water pump hub.
  1. Pull fan clutch and fan blade off water pump pilot and remove fan clutch, fan blade and shroud from vehicle.
  1. Remove four screws and separate fan clutch from fan blade.
Item Part Number Description 1 8509 Water Pump Pulley 2 57632-S Screw and Washer Assembly, 5/16-18 x .62 Hex 3 8600 Fan Blade (5.0 and 5.8L) 4 8600 Fan Blade (7.5L) 5 8A616 Fan Clutch 6 380288-S2 Screw and Washer Assembly, 5/16-24 x .88 Hex A — 16-24 Nm (12-18 Lb-Ft)
Mar 10, 2009 | 1994 Ford F150 Styleside Supercab
Waterpump removing fan
Well, if it's a 5.0L engine, remove the 4 bolts holding the fan to the pulley. If it's a 4.0L engine, you need to hold the waterpump pulley still and break the nut loose holding the fan clutch to the waterpump. If you don't have a wrench that big, try using a long chisel on the edge of the nut and hitting it very hard with a hammer to break it loose.
Feb 15, 2009 | 1996 Ford Explorer
Changing Smeg SA280X/1 fan motor, shaft nut stuck?
Most fan blades are held on by a single nut, which is usualy a left hand thread, so to unscrew it you turn it clockwise as though you are tightening it up.and to tighten it,anticlockwise..
If the spindle turns, then you will have to hold it with a pair of grips or similar.
Plz rate my solution.
Jan 10, 2009 | Smeg SE280X Stainless Steel Electric...
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
135 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
