Question about HP Photosmart C6180 All-In-One InkJet Printer
Hp C5100 printer error code oxc18a0001 - HP Photosmart C6180 All-In-One InkJet Printer
  • 1T123 Feb 23, 2009
    My HP Photosmart C6180 is giving me an ink system failure error code 0xc 19a0013. Following these instructions The printer printed a diagnostic in which the colors printed fine, but the type is so light it is barely ledgible. What could I try next?
  • 210 Answers
I had a similar problem of a senseless printer error code with similar useless help from HP for one of my client's HP Photosmart 7510. I also could not find any other relevant help online. But, while searching, I did notice a suggestion to clean the contacts. When I removed the ink cartridge carrier, I noticed a large build-up of ink around the nozzles. Cleaning out the carrier did the trick for me. It couldn't hurt to give it a try.
Follow the steps below if you need them. And, please click "Yes" below if this has helped you at all.
Remove the carrier: Open the printer to access the ink cartridges. Slide out the ink cartridge carrier if it is parked. Remove all of the cartridges. Then flip the lever to the right of the carrier. Grasp the carrier using your thumb on one side and index/middle finger on the right, both near the top, and pull straight upward. Careful, yours may be more full of ink than my client's was.
Clean the carrier: Wash the carrier in a sink with warm/hot water at various angles until all noticeable ink is cleared away. Briefly wash water directly into the carrier's induction screens which contact the sponges of the ink cartridges. This may help a little to flush any ink from the nozzles which might have dried in them while the printer was inoperable.
Remove most of the water: Shake the carrier downward (only while upright) and tip the carrier forward and side ways. But, be careful since some ink will still be contained in the carrier's ink channels. Pay close attention to the induction screens. If you tip it too far or shake while inverted, ink may splash out through the screens or drain back onto the carrier. If this does occur, repeat the cleaning procedure.
Note: Do not attempt to drain all of the ink from the channels, whether through the induction screens or through the nozzles on the underside of the carrier.
Dry the carrier contacts: Lightly wipe the tiny metallic white squares on the backside of the carrier with a dry paper towel. Spot dry the surrounding area, including the nozzle arrays on the underside of the carrier - dab, don't wipe. You should get ink spots on the towel from the nozzles. This is to be expected and is a sign that the nozzles are not clogged (at least not completely).
Inspect the carrier transport: Examine the area with the metal prongs that were exposed when the carrier was removed. Dab dry any areas with ink if you find any, especially near the metal prongs. If you discover any ink on the prongs, use a wet, but drip-dried cloth or towel to continuously dab the prongs until they are clean. Then dab with a dry cloth or towel. Re-inspect and ensure any lint or other debris is removed from the prongs.
Reassemble and test: Return the carrier to the transport, flip the locking lever to the downward position, return the ink cartridges, and then test your printer.
I hope this helped and that all goes well. Please click "Yes" if this has helped you at all.
Posted on Mar 30, 2014
  • 679 Answers
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer. Please let me know if the issue is not resolve so that i can check for a possible solution for that. Thank you so much.
Posted on Feb 03, 2009
HP 3210: Fehler Oxc 18a0001
The only way to fix Oxc18a errors is to reset the printer. You can find the instructions on website here:
HP ink system failure error HP maintenance error what to do if HP printer...
Jan 01, 2015 | HP Photosmart 3210 Printer
How to override error Oxc18a0001
If you have a C6180, the error code you give here is not in the manual, so you better contact HP service centre like the manual explains.
Jul 21, 2014 | HP Photosmart C6180 All-In-One InkJet...
Do try to give more information.
May 15, 2014 | HP Office Equipment & Supplies
Code oxc18a0001
disconnect the printer, remove ink cartriges, turn printer off, wait a minute, then turn it back on, replace ink and connect to computer again. If this doesn't work you will need to contact HP support,
Same error code on HP 3210 HELP!
Its an internal error which means that there is some issue with the ink delivery system of the unit. Since the ink delivery system cannot be replaced the whole unit needs to be replaced.
No reset or any other steps will resolve the issue.
Jul 31, 2009 | HP Photosmart C7280 Laser Printer
Hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Jul 16, 2009 | HP Photosmart D7460 Printer
Error message oxc18a0001 ink system failure
Go to HP website, I recall some info there on this
Apr 25, 2009 | HP Photosmart 3310 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
844 people viewed this question
Ben Johnson
