Question about Rockford Fosgate T10001BD- Car Audio 500watts Mono Power Amplifier Car Audio Amplifier
When amp powers up it makes a buzzing noise-quite loud-
As soon as amp is powered up it makes fairly loud buzzing noise-this is with no speakers connected or rca's connected!
    Scholar:
  • 148 Answers
Probably a loose coil or bad ground in the amp itself. Contact www.audiotekx.com, ask for Jason, he can help you and is the best out there. The problem you're having is extremely tricky to rectify, I had an amp with the same problem at it stumped multiple techs, some that had been in the business 35 years, yet Jason got it solved.
Posted on Nov 02, 2006
SOURCE:
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Guitar amp continuous humming
Main power supply filter capacitor(s) might be bad.
Mar 11, 2014 | Audio Players & Recorders
My speaker makes a realy loud buzzing noise when I turn the power on
Try turning the volume down before disconnecting.
Jan 06, 2014 | Car Audio & Video
Loud humming noise from under my Tahoe. 2WD
The noise is your fuel pump which should hum, but not buzz. It is going bad & will need replaced soon.
murf427
Aug 02, 2012 | Chevrolet 2001 CHEVROLET TAHOE Chassis...
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
Sound on Olevia 237T cuts out but comes on again if I change channels. Sometimes i get a loud squeal or buzz, which also stops as soon as I change channels. How do I fix this?
You need to find out if the prolem is in the power amps that drive the speakers are bad or not, Try using Powered PC speakers hooking it up to the Audio line out RCA jacks to see if you get the same problem. If it is OK then the problem is in the power amp sections, it can be bad power amp IC of bad filter capacitors in the power supply that provided power to the power amp circuits.
Nov 01, 2009 | Olevia 237T 37 in. LCD TV
The noise is a hum or buzz. We've narrowed it
By chance have you tried making sure the laptop is not too close to the speakers? Sometime you will get feedback when the source is to close to high powered speakers. Also, check your jack cord and make sure no splits/cuts are visiable and the plugs are fully inserted.
Good Luck and keep making great music. Aloha.
C2Solutions
Sep 02, 2009 | Dell Inspiron 6000 Notebook
Make loud buzzing noise when powers on
Actually that buzzing sound seems that it might be an issue with your ballats, it may start to go out sometime soon.
Jul 26, 2009 | Toshiba 52HM95 52" HDTV Projection...
Speakers making loud buzzing noise
From your alternator, Make sure none of your RCA's are near a power wire, check your grounds as well.
Jan 09, 2007 | Pioneer TS-D690R Coaxial Car Speaker
Car Audio & Video Logo
338 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
