Question about Whirlpool Washing Machines
Won't fill with water - Whirlpool Washing Machines
  • michaelt721 Mar 25, 2009
    Is it the water supply valve even the cold water works, but the hot doesn't?
    Genius:
  • 1,122 Answers
YOU NEED A NEW WATER SUPPLY VALVE LOCATED ON BACK OF WASHER WHERE HOSES GO ON,GET THE MODEL NUMBER OFF THE WASHER AND GO TO SEARS .COM CLICK ON PARTS PUT YOUR MODEL NUMBER IN AND YOU CAN ORDER THE PART YOU NEED,LET ME KNOW IF YOU NEED HELP PUTTING IT ON-MIKE
Posted on Nov 01, 2008
My dishwasher won't fill with water. and keeps running even when the door is open.
A defective switch may interfere with your dishwasher's filling ability. Yourdishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Dishwasher Repair Guide - Dishwasher won't fill with water..
or try this link..
dishwasher won fill with water Google Search
Oct 27, 2017 | Dishwashers
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
Whirlpool Sm8525079 Rev fills up with water, but won't agitate.
Your lid switch has a fault, Sometimes the switch can bend which means that it won't always operate.
Mar 08, 2012 | Washing Machines
Maytag_lse7804ace: washer won't fill with water. If I fill it by hand, the cycle works fine (until it gets to the rinse cycle, when it won't fill again).
Hello John,
The most probable reason the washer is not filling is because of a blown fuse that is part of the lid switch asm. By UNPLUGGING THE WASHER and removing the 2 INNER screws on the the control panel and the control panel can be rotated down to see the fuse in the lid switch asm. Here is where the fuse is on the switch asm. its circled in red 11_4_2011_1_39_54_am.jpg
Nov 03, 2011 | Washing Machines
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
