Question about Matsonic MS9317E Motherboard
MS9317e+ manual Does anyone know where I can obtain the user manual for this motherboard??? OR other than SDRAM what other memory can this motherboard take???
  • mousemat Nov 01, 2008
    Thanks for that, very helpful and with great speed.
  • 94 Answers
CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
400/533 MHz FSB Chipset SIS 651 + 961 MS9317E+
SIS 651 + 962 MS9317E+(USB)
MuTIOL® Delivering 533MB/s Bandwidth Memory Supports two 184-pin DDR DIMM maximum size up to 2GB
Supports two 168-pin SDRAM DIMM maximum size up to 2GB
Support DIMMs of DDR333/DDR266/PC133 CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
Support DIMMs of DDR333/DDR266/PC133manual for this board is no longer available but above is your mobo info
Posted on Nov 01, 2008
  • Andy Bathgate
    Andy Bathgate Nov 01, 2008
    if you need help decyphering this add a comment and i will translate
Hi can anyone tell me what type of RAM is used in the Asus P4SGX-MX Motherboard please. Chris.
Your motherboard has 2 (DDR) and 2 (SDRAM) slots. DDR and SDRAM memory modules cannot be used simultaneously, and the maximum capacity is 2GB of RAM. So you can put in either DDR or SDRAM modules.
http://www.memoryc.com/asus/13039_p4sgxmxmemory.html
Jan 29, 2011 | ASUS P4SGX-MX Motherboard
Hi. I'm trying to get ahold of a manual for the pcchips m810dlu motherboard. I need to know what capacity of rams can be stored on the board; 2700, 3200, etc. Thank you
• 2 SDRAM DIMM Sockets
- Two 184-pin 2.5V DDR SDRAM (DDR200/266) or
- Two 168-pin DIMM Socket for SDRAM memory module
• Maximum: 1GB
Aug 07, 2010 | PC Chips M810DLU (M810DLUV75C) Motherboard
Need Manual for Slot1 PIII Gateway Jabil Tabor III Motherboard.
The memory specifications for that motherboard are as follows:
  • 100-megahertz (MHz) Memory Bus Speed (FSB)
  • Three 64-bit or 72-bit Error Checking and Correction (ECC) 4-clock, 3.3V, unbuffered synchronous DRAM (SDRAM) Single or double-sided DIMMs in the following sizes: 8 MB, 16 MB, 32 MB, 64 MB, 128 MB
  • Expandable to 384 megabytes (MB) of SDRAM, CAS latency of 2, using 64-Mbit chips
  • DIMMs must adhere to the Intel 4-clock 100-MHz 64-bit unbuffered SDRAM DIMM specification, latest revision
  • Uses gold-plated DIMM socket
  • ECC signal and multiple bit detection, single bit correction, supported, using ECC DIMMs, can be enabled and disable in the BIOS Setup Utility
  • Jun 21, 2009 | Gateway Computers & Internet
    Gigabyte GA-60X Memory upgrade.
    Hey syconus, Matt here- It will unfortuatly still only take the 512mb because it is not compatible with the new memory. Sorry:|.
    Dec 31, 2008 | Gigabyte GA-6OX Motherboard
    I NEED RAM
    Hi zouganeli,
    You can install one, two or three modules. Each memory module can hold a maximum capacity of 128 MB of standard SDRAM chips, or 256 MB of registered SDRAM chips so maximum memory capacity is 384 MB of standard SDRAM memory or 768 MB registered SDRAM memory.
    Hope that helps
    Take care,
    Michael
    Nov 14, 2008 | Computers & Internet
    I need your help me
    You need to upgrade your memory modules to a bigger size, check your motherboard manual for supported memory speeds.
    You can also look at your current memory be removeing it from the socket and see what it reads on it. Its either DDR memory or older SDRAM. I beleave your maximum memory is 3 GB
    May 27, 2008 | Biostar U8648 Motherboard
    Ram
    Hi roniduncan,
    Your Intel D865GBF motherboard does not support DDR2 memory.
    The D865GBF motherboard does support.
    DDR400, 2.5 V Dual channel and up to four 184-pin Double Data Rate (DDR) SDRAM Dual Inline Memory Module (DIMMs) connectors with gold-plated contacts.
    Do not have your manual? Download from this link.
    http://support.intel.com/support/motherboards/desktop/d865gbf/sb/cs-008983.htm
    Please turn to Page 17 in your user manual. (Memory specs).
    Inte D865GBF motherboard main web site.
    http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=948&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
    Any more questions? Feel free to ask.
    Mike
    Apr 23, 2008 | Intel D865GBF Motherboard
    ECS k7SOM+ 1.0 Motherboard, 1.3 AMD DURON
    According to the manual the board supports 1 gig of either SDRAM or DDR .
    LINK
    Click on the link click on USA
    On page 6, I believe is the following specs.
    • Two 168-pin DIMM slots for SDRAM memory modules
    • Two 184-pin DIMM slots for DDR memory modules
    • Support SDRAM up to 100 MHz / DDR up to 200 MHz memory bus
    • Maximum installed memory is 1GB
    Note: You cannot use SDRAM and DDR simultaneously.
    Mar 26, 2008 | Intel Motherboard
    To extend RAM memory
    No its isnt sorry :(
    Only sdram will fit in the slots. Best place for getting it is 2nd hand off ebay.
    Hope that helps?
    Jan 05, 2008 | Intel 845GE Motherboard
    Missing part
    Hi, Sorry to tell you but this motherboard supports ONLY SDRAM memory. There is no way that a DDR memory will fit into this motherboard. What you can do is add another SDRAM memory for better performance.
    Apr 28, 2007 | Syntax SV266A SKA KT266A Motherboard
    Matsonic MS9317E Motherboard Logo
    1,562 people viewed this question
    Top Matsonic Computers & Internet Experts
    David
    David
    Robert Karst
    Robert Karst
    aravind shet
    aravind shet
    Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
