Question about Gaggia Coffe Deluxe Coffee Maker, Espresso Machine
Gaggia Synchrony Compact Digital Problem
Mirran:
I have had my Gaggia Synchrony Compact Digital for 3 years with no problems. Two months ago it began leaking water from the steam tube after turning it off. I replaced the steam valve. This fixed the leak, but I got into a continuous "ventilate" problem, which I cannot solve. Last night I decided to run it through a rinse cycle and now it won't end the rinse cycle and no water is being discharged. I unplugged it overnight and this morning it remains in the rinse cycle, but discharges no water. Can you help?
  • nae5372 Nov 11, 2008
    Thanks for the suggestion, but this did not work. In fact, I have received several suggestions and none of them have fixed the problem. It appears that it is time to send the machine in for repair. I appreciate your help.
  • 515 Answers
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
/Mirran
Posted on Nov 08, 2008
My Gaggia Synchrony is leaking - If I remove the water catch basis, I can see a drip. We have used this machine every day for years - can the problem be fixed easily?
HI
There is a panel behind the brew unit, that has 2 screws. Remove it and clean the coffee residue behind it. That is what drains the pressure relieved after brewing, and has coffee residue that can build up and cause the leak. It should leak into the drip tray though, except when you rremove it.
Oct 23, 2010 | Gaggia Syncrony Compact Coffee...
I was descaling my machine (gaggia synchrony- 3 years old). After it ran thru the first cycle & I refilled it I can't get it to heat up again & it shows a light indicating there's no water- when...
Make sure that the sensor in the water tank has not stuck IIRC it's on the right hand side as you look at the machine from the front. Then run some water through the steam nozzle, it could just be that following the descale there is no water in the boiler and you just need to fill it as you did when it was new.
Hope this helps.
Aug 17, 2010 | Gaggia Syncrony Compact Coffee...
I have a Gaggia Digital Syncrony. The machine
Hi
You could have a micro switch in the doser that is going bad and needs to be replaced. They are a special micro switch that is very sensitive and can get stuck with a little coffee dust inside the switch.
Mar 10, 2010 | Gaggia Syncrony Compact Digital Espresso...
I have a Gaggia Syncrony Compact Digital, almost 2 years old, recently the digital display has been fading and today once i turn the steamer off, it still steams at a slow pace and evenutally it stoped,...
The steam valve has been leaking on the inside for awhile, the steam condensed on the display board. You will have to replace the steam valve assembly and maybe the display board.
Jan 20, 2010 | Gaggia Syncrony Compact Digital Espresso...
Gaggia Syncrony not dispensing properly
It sounds like you need to program the coffee level.
Have a look on this page for the instruction manual.
http://www.coffeeitalia.co.uk/downl-manual.php
Jan 04, 2010 | Gaggia Syncrony Compact Coffee...
I need to replac steam valve for gaggia syncrony compact, where can I get the parts?
I get parts for my Synchrony from Cerini.
http://www.cerinicoffee.com/Gaggia_parts.asp
There are a couple of different stram valves. Call them to get the right one.
Nov 14, 2009 | Gaggia Syncrony Compact Digital Espresso...
I have an old larger version of the Digital Synchrony and have a message that says 'hot water ventilate'. I have tried to run hot water through the machine using the hot water tap/button but nothing...
Check the end of the steam spout that may be blocked, use a paperclip to clear. If you still get the same result then the machine needs to be descaled.
Oct 08, 2009 | Gaggia Syncrony Compact Coffee...
I have a Gaggia Synchrony compact. I recently decalsified it and it stopped working. The low water light is on and nothing works except, for the water pump. It will flow only cold water through the steam...
If it leaks from the steam wand then you need to get a new steam valve assembly. For the heat you will have to open the machine it is possible that the steam boiler is damaged or that the thermostat on there is bad, use an ohmsmeter to check thermostats and element. There are 2 screws in the grinder, 2 behind the water tank and about 2 or 3 in the front behind the door.
Jun 09, 2009 | Gaggia Syncrony Compact Coffee...
Doesn't power up
Same problem here, working one minute, lights out the next. No signs of life. Hoping there is a fuse or breaker somewhere.
May 12, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Logo
200 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
