Question about Sony XM-2150GSX Car Audio Amplifier
Amp overcurrent problem
I have an XM-2150GSX sony 760 watt amp, not the best, but my overcurrent light comes on every time i turn the amp on, what is the problem???
  • 3 more comments
  • Anonymous Mar 06, 2008
    I have the same prob.
  • jagarcia8787 Jan 14, 2009
    My overcurrent light turns on everytime i turn on the amp. The fuse is not blown I checked the wiring it all seems to be ok.
  • Anonymous Jan 21, 2009
    MY OVER CURRENT LIGHT COMES ON EVERY TIME I TURN MY VOLUME UP
  • Anonymous Mar 15, 2009
    someone told me it could also be caused from a bad ground
  • mrjrc13 May 22, 2009
    I have the same problem and same amp.; maybe its a default in the 760 watt amps
  • 631 Answers
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (overcurrent), the amp likely has blown output transistors.
Posted on Jan 05, 2008
Just open your amplifier and you should not look muevban the componestes only get if you have a welding and soldalo Cautín and I had the same problem and this is just about the meaning
Posted on Apr 07, 2009
Overcurrent lights comes on whenever my amp is on
this can only mean 2 things, either your over working the amp, which means your amp is trying to push power that it don't have, and it's getting hot which is known as thermal mode. and the other reason can be that make sure amp rms. matches the rms. of your subs.
Mar 13, 2010 | Sony XM-2150GSX Car Audio Amplifier
Its on over current
when the overcurrent light lights up, this means the amp is being run too hard or too loud. try cutting the gain back a little. i always hated putting in the sony amps that had those lights on it. it seems that when you turn it up and get it sounding good the light comes on.... if the overcurrent light is on all the time and it doesnt make sund....the amp could be bad. good luck.
Dec 17, 2009 | Sony XM-754SX Car Audio Amplifier
I have Sony XM-2150GSX amp on offset cant get it off
check for a short on one of the edges or a resistor on the edge of the board
Jul 04, 2009 | Sony XM-2150GSX Car Audio Amplifier
Amplifier keeps running overcurrent
sounds to me like you are overheating the amp, try down tuning the peak level of the amp, and also if there is anything around the amp clear it away, check if the fan is turning on, you may need to replace it,
May 20, 2009 | Sony XM-2150GSX Car Audio Amplifier
I have an xploid 760 same amp wit ha 800 watt sub. eb=verything should work fin. but the same prob when i turn up the valume the overcurrent kicks on
use a bigger ground wire for amp and protect mode will stop clipping and shutting amp off also make sure power wire and ground wires aren't the same size ground bigger .............if this doesn't help change settings on amp to lower power
easiest way to set amp is (turn the knobs on amp all down turn up your system to the level you listen to normally and then set the amp knobs for bass turn knob slow to set properly but i think the ground needs to be bigger and maybe moved to a new location
hope this helped
Mar 03, 2009 | Sony XM-2150GSX Car Audio Amplifier
Overcurrent comes on when i turn up the volume on my head unit
The over-current LED tells you that you're driving a lod lower than the amp is rated to drive. You either have the wrong speaker ohm load, a shorted wire or a defective speaker.
Apr 30, 2008 | Sony XM-2150GSX Car Audio Amplifier
Need a lil ore help!!!
If the overcurrent of DC offset lights are not green, the amplifier probably has blown output transistors.
To eliminate other problems, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally (all lights green), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Jan 05, 2008 | Sony XM-2150GSX Car Audio Amplifier
Sony XM-2150GSX Car Audio Amplifier Logo
1,552 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
