Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Kenmore Portable Washer will not agititate
My Kenmore (model 84671100) fills and does not proceed to the agitating.
It also makes a high pitch sound after the filling. If I do not turn the machine off the high pitch stops and returns. It sounds like it is attempting to do something but can not proceed. Any ideas on what can be causing this problem? How should it be repaired?
Thank you
  • 1,122 Answers
Posted on Nov 01, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
Dec 03, 2015 | Washing Machines
My washer will fill up and then skip the wash cycle, it will then drain rinse and then spins it out, any ideas?
Top load washer check the agitator dogs located inside the agititator here is a video if you have a top load washer on how to change the agitator dogs as well if you have a front load washer message me back for further diagnosis. Thanks Rick
Jul 09, 2011 | Washing Machines
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not spin.
Check the lid switch. Many models will not drain if the lid switch is bad. Hope this helps!
Feb 16, 2009 | Kenmore Washing Machines
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Agitator moving just a little.
If it is a Whirlpool or Kenmore make washer you probably stripped the "dog ears" in the agitator. They give you the duel agitation that makes your clothes cycle from top to bottom of the machine. Should only rin you around $8.00 or so. Hope that helps.
Jan 24, 2009 | GE WBSR3140DW Top Load Washer
Kenmore washer fills and agitates at same time
it sounds like the timer is going bad
Oct 22, 2008 | Washing Machines
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore Super Capacity Washing Machine
If your washer is the one you have chosen a Whirlpool built kenmore unit than your washer doesnt have any bearing that fail, It could be the spin tube mounting block becoming stripped ( most common) or a clutch or brakes not releasing issue (not likely). Also make sure the machine is agitating it may just be filling with water and draining and making motor noises. In this case the motor coupling has broken. both the block and coupling are inexpensive parts and easy to install.
Jan 14, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
125 people viewed this question
Sal De
 Brian Main
Brian Main
