Question about Philips GOGEAR SA6045 MP3 Player
Wont play wma files
I have installed everything it comes with, it will upload mp3 and wma files ok but wont play the wma files - comes up file not supported, but the wma files upload and play fine on my old mp3 player - what do I do??!!
  • staceyjw Nov 02, 2008
    How do I do that? I have Windows XP and am using Windows Media player, and I keep trying different things, but no idea really!
  • Anonymous Mar 25, 2014
    the music files show up on the computer but not on the mp3 player
  • 638 Answers
Different players will accomodate different formats. You might have to reformat the WMA files on your PC and then transfer to your unit.
Posted on Nov 01, 2008
  • TO Lady Nov 03, 2008
    This program will convert your files from WMA to MP3 format. These should play on your MP3 player after conversion.
When trying to play music the display shows "Unknown Format"
Only MP3 and unprotected WMA files re supported. If you upload copy protected WMA files or any of the iTunes AAC formated songs, they will not play. All purchases from the iTunes store have to be converted to MP3 before they can be played on this player.
Also, some older MP3 players will not be able to play MP3 audio encoded at high bitrates.
Apr 21, 2011 | Eclipse CLD2BK MP3 Player
SwiMP3 (128 MB) MP3 Player: I have the original first version of the Swimp3 pl...
This could actually be an easy fix. If you have any files on the player that are not WMA or MP3 files, or that you've stored your music in folders - either way it could simply stop the drive from playing.
Incompatible Music Files: If you have loaded a music file that is not compatible, it simply won't play. The SwiMP3 player works with mp3 or wma files, but not aac (like from iTunes).
Solution: Remove the incompatible files. Convert your other music files to mp3 or wma, and if you are importing your songs direct from itunes, you'll need to convert them to mp3s first.
Incompatible NON-Music Files: An MP3 player is similar to a Thumb Drive or Flash Drive because it can hold any kind of file that will fit in the drive's capacity. However, if you have loaded an incompatible file - including JPEGs, Cover Art, Word Docs, anything that is not an MP3 or WMA file, the player simply can't translate it into music.
Solution: Remove the incompatible files, leaving only your mp3 or wma files in your root directory.
Folders: The mp3 player is not able to open folders and play music files stored inside, to the Swimp3 player the folder is simply an un-playable file.
Solution: Open the folders, move or copy the music files into the root directory (remember, mp3 or wma - not aac), then delete the folders.
I hope you find this helpful.
Michelle
Swimp3 Troubleshooting Video
May 18, 2010 | Finis Swi MP3 Player
My insignia does everything just fine except play video
Supported formats for this player include:
Audio: MP3, WMA, WMAPro, WMAlossless, Secure WMA, Audible, OGG (tracks will only be recognized in File and Folder (MSC) mode) Video: MPEG-4, WMV
You may encounter playback issues if the file is corrupt or is not really of the file type indicated by the extension. More information about this player, including useful downloads, can be found at InsigniaProducts.com.
Feb 25, 2010 | Insignia Pilot MP3 Player
Nextar MA933A-20P will only play factory installed files.Music files add are present but will not play. Will only shuttle between classical and fast dance files
The following may help:
1) Ensure that your Music files are of the correct format (usually .MP3 or .WMA suffix and usually NOT .WAV which is the standard CD format)
2) Ensure that you upload your music .MP3 or .WMA files to the correct directory and names are not excessively long as some MP3 will limit the max name length. If you know a working song on your MP3, locate the directory it resides in and put your songs there. 3) If you have uploaded your songs with the correct naming convention/suffix and you now see them in your player list but they will not play, then your MP3/WMA file has non-compatible 'property' whcih is usually the encoding 'bit rate' (usually anything under 128mbps fix rate is good but you can see what is acceptable by looking at the 'properties' of your working songs that are on your MP3 player) ps. To reformat your Music files to the player acceptabel format, you need to download and use a 'Audio Media Converter'.
Dec 20, 2009 | Nextar MA933A MP3 Player
It wont play the downloading songs
- Ensure that your Music files are of the correct format (usually .MP3 or .WMA suffix and usually NOT .WAV which is the standard CD format). - Ensure that you upload your music .MP3 or .WMA files to the correct directory and names are not excessively long as some MP3 will limit the max name length. If you know a working song on your MP3, locate the directory it resides in and put your songs there. - Lastly, if you have put your song with the correct naming convention/suffix and you now see them in your player list but they will not play, then your MP3/WMA file has non-compatible 'property' whcih is usually the encoding 'bit rate' (usually anything under 128mbps fix rate is good but you can see what is acceptable by looking at the 'properties' of your working songs that are on your MP3 player)
Dec 19, 2009 | Element Electronics Zr-Element Digital...
Music downloaded as WMA from PC to MP3tech MP3S4 wont play
Your player should support both MP3 and WMA files. What happens when you try to play an MP3 instead? Have you tried other bit-rates? Those you are trying may be too high or low.
Jun 29, 2009 | Audio Players & Recorders
"No files message" on player after uploading music
Check whether the file format is mp3 or wma and also try changing your XP service pack and then try transferring files or Use winamp ( Newest version ) to transfer your files ..hope it helps
Jun 22, 2009 | Trekstor 74412 i.Beat emo MP3 Player
Music files on MP3 player not playing due to license problem
This player was made before the advent of the DRM license system. You will have to use mp3 files or UNPROTECTED WMA's. DRM-license-protected WMA's - which is what most music services use - will not work on this player.
-Tha Mp3 Doctor.
Mar 02, 2009 | Philips GoGear SA178 MP3 Player
Media player will not recognize my 256 tx fm mp3 player
For your MuVO TX FM, there are a couple of other components you should download and install from the Creative download page for this player.
In addition to the latest firmware, which you've already installed, make sure you have the Creative Mass Storage Driver 1.07.00.250. This should allow your computer to communicate with the player.
Also, install the Creative MediaSource Player/Organizer 5.10.38. This should allow you to sync WMA files to your player with the proper licenses.
May 15, 2007 | Creative Labs Nomad MuVo TX MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
203 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
