When i start my laptop it just keeps going in to startup repair and will not start windows
  • bat21talbot Nov 01, 2008
    will not let me boot in safe mode
    Genius:
  • 1,250 Answers
Boot your system in safe mode then check, if it boots restore it to some previous date
Posted on Nov 01, 2008
My screen keeps flashing" diagnosing your PC" why
There is a problem with your windows 8 PC's installation, which has stopped it from booting correctly; hence why it starts in 'startup repair', and tries to diagnose your PC. Hold the F8 key while booting your computer to go into the startup menu for Windows; click Advanced startup options; and select Restore my PC; which will reinstall windows.
This may or may not work for your machine, you may have to hold F2, F10, or the Escape key to go into the UEFI setup and go into startup options from there.
Dec 20, 2013 | Gateway Computers & Internet
My toshiba n723 says i need a windows 7 start up disc. where do i get this?
you just need to repair windows startup. and you can do it by bootup window 7 disk and go to repair opption and find startup repair opption.
this opption will solve out this problem automaticly.
Feb 14, 2013 | Toshiba Computers & Internet
My Presario CQ60 is stuck in recovery manager mode. I keeps going to startup repair.
Problems starting up a PC can be tricky to fix, since Windows hasn't had a chance to load its arsenal of troubleshooting tools. Some people simply give up and reinstall Windows.
Startup Repair can prevent a time-consuming reinstallation by diagnosing and repairing problems that prevent Windows from starting.
Startup Repair is designed to start automatically if Windows detects a startup problem. For more information about using Startup Repair, and what to do if it doesn't start automatically
here is my solution... when you boot your window when you're middle in dos loading press F8 and select boot in safe mode... then when you are in windows click start --> all programs ---> accessories---> sytem tools ---> system restore... hope you back up your windows.... try to restore your window in earlier time...
HOPE IT HELPS AND GOD BLESS
Jun 27, 2011 | Compaq Presario CQ56-115DX Laptop
I can't get my note book to start up in safe mode with networking it just keeps going to the tech guys screan and won't start in safe mode.
Hello
When your Advent laptop isn't booting properly, you probably have a problem with your startup disk. When the startup disk is acting up you may take it to a repair shop, or you may save a lot of money and fix it yourself. Windows 7 computers come with built-in software that will allow you to repair your startup disk in just a couple of minutes.
Start your computer and press down on the "F8" key. Click on the "Repair your computer" option in the "Advanced Boot Options" menu that appears on the screen.
Press the "Enter" key.Choose your keyboard layout on the next screen and click the "Next" button.
Click on the "Startup Repair" tool in the "System Recovery Options" screen.
Wait for the computer to repair the start-up disk
Apr 12, 2011 | Advent Netbook
My laptop will turn but keeps coming up Windows faild to start. A recent software change might be the problem and then it asks me to insert the windows installation disk which i do not have could you help...
Hello Antony, try pressing F8 just before it tries to start up. You will have to wait for about 5 secs and then press it. That will bring you up to a startup repair screen, then just highlight that you want to repair startup problem stopping your laptop from starting. If this doesnt work just go to create restore point,which will restore your pc to before the problem began. If all of that doesnt work you will have to run a startup program,but try those things first. Good luck.
Mar 27, 2011 | Toshiba Satellite Pro L300 Notebook
Hello, I have an HP Pavilion dv2000 laptop. The problem is the laptop keeps freezing on startup.When I first turn it on I get a screen that says "Windows failed to start" and gives me two options: Launch...
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reginout
Sep 22, 2010 | HP Pavilion dv2000t Notebook
I have accer 5570 Laptop when ever i start it up it gives me this message on and off and wont let me start the window here what it says" windwos Erro Recovery-windows failed to start. A recent Hardware or...
Tried starting normally & go int contol panel on the start menu,system tools & system restor to last good setting!
Hope that helps but if not get back to me!
Sep 22, 2009 | Acer Aspire One AOA150-1784 Netbook
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
Tom
You should go into the safe mode and try to uninstall or undo the previous work. Else use the system restore. But if it continues again with a blue screen error, then u should format ur pc, further if u experience blue screen error then u should note that one of ur hardware is damaged.
Thankyou...!!!
Feb 08, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
