Question about Sony KP-61V45 61" Rear Projection Television
Blue screen Hello there. I received this model tv about 1 year ago. approx. 3 mos. later the tv just shut down with a low tone dull noise. I tried to turn it back on and only a blue screen would show with some thin white lines. 6 seconds later the tv would shut down with the same noise as explained. I was told to pick one side of the tv up and drop it lightly, that seemed to fix the problem! it worked for 6 mos. and now the same problem arose but only this time it has a red screen insted. So, I removed the back cover and turned the tv on and noticed all three tuners would come on briefly then all power would shift to the red tuner making it atleast 3 times brighter than it had. that would last 3 sec. or so and just shut down. I started to tap components (I was carefull) and i tapped a part that was sort of like a distributor it had one wire going in and 3 coming out to the tuners. The part is completely sealed. what is this and is it a cheap part? Thank You
    Sergeant:
  • 337 Answers
It sounds like the high voltage distribution block but that is not the cause of your problems,the tuners you talk about are the picture tubes ,one for each color,the blue picture tube was arking and you got lucky and got 6 more months of use, it and might have corrected when you drop it but now is the red doing it and you need to do the same but it might not work this time,dont be surprise.Be carefull while trying things in the back,there are high voltages there and is not safe unless you are familiar with tv service.
Posted on Sep 20, 2006
Hello, I have a Samsung HLP4663W 46 in. Rear Projection HDTV Television, and they lamp kept going out so I bought the proper lamp to replace it and it still would not show a picture. Should I pay to have...
Recheck the tv projection lamp installation?Recheck the lamp door latch,see if it is proper closed and tightly closed of the lamp door?Hear any clicking noises,when the tv projection lamp tries to ignite up.If hearing constance clicking?Mean the tv board that call the Ballast board it is also dead,this Ballast board only job are to ignite the tv projection lamp only.Ballast board must have be replaced.If the tv have a colors wheel is it dead or damage and broken require changing,u will hear major humming,motor or grinding sound noises and alot of times the tv pictures flashes multiples colors on the tv screen or the tv pictures will have a black&white flashes of a background of white light within the tv pictures background.Selling defective tvs almost impossible to sell it for a decent or a good priced or it at all.If this tv u have less than 5 years old,tv it is still have alot of it life ahead of it,tv tube picture screen panel,will last u atleast another 10 years and have to be 8 hours tv whatching every day to dies this faster or could be last to 15 years,if tv less hours of watching every day.Should get priced quotes from many tvs repair shops and get it fixed max prices about $400-$500 dollars.New tv same model and sized or difference models too will cost u like $1,200-$1,500 dollars.
Aug 06, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Blue cloud looking mass on left side of screen, makes skin tone pink on that side, okay on right side. what could be causing this?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 02, 2011 | Hitachi 51F500 51" Rear Projection...
Model 43fdx20b there is a yellow 1/2 moon at top of picure from left corner down approx.6" and back uptoright corner, blue ghosting below that. what exactly can I do to fix and how much for parts ...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2011 | Hitachi 43FDX20B 43" Rear Projection...
Hello i have a sony KP-46WT510 model 45" TV, and
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
This is a very common failure on Projection TV sets and a fairly simple DIY fix.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc
Feb 18, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
There is a redish pink tone to the color and i cannot get it back to normal even after trying magic focus several times
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 10, 2011 | Hitachi 57F500 57" Rear Projection...
Our Phillips Protjection TV model: 55P9161, picture is very dark, and fuzzy. There are tones of Greens and ghosting. We have followed convergance, and the other tips on the Phillips site but nothing has...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 26, 2010 | Philips 55P9161 TV
My Samsung DLP model HL-P6163W keeps turning on and off and now lights are flashing. We replaced the color wheel last year and about two years ago the lamp.
could still be the lamp but it could also be the Ballast for the lamp has failed. I've replaced a lot of Ballasts on DLP machines.
Nov 17, 2009 | Samsung 61" Slim-Depth DLP HDTV
Picture was fine, then lines diagonally, now light
Projection sets have two very common problems outlined below.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngSOLUTION
Oct 10, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Televison & Video Logo
57 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
