My dell dimension 2400 series computer has lost comms with the local dell AIO A920 printer. Connections seem to be good. It seems a print job has got stuck somewhere. HELP! AJCook
  • polsham Nov 01, 2008
    control panel shows document that refuses to cancel
    cannot uninstall printer while message is stuck!
  • 94 Answers
Have you tried purging pending print jobs? Go to Printer and Faxes on XP, then right click on your printer icon then select purge print jobs. Or double-click on the printer icon on your system tray (lower right hand of the screen) then click on the pending print jobs then purge it. Then try to print again.
If you can't purge or cancel a pending print jobs, try to check for any virus on your computer.
Posted on Nov 01, 2008
  • 19,396 Answers
Open the printer window from control panel>>printers and faxes>>installed printers and remove all jobs in the printer cue.
If the stuck process does not go from the cue, unplug printer power and if used also USB conn., restart computer, and remove the stuck print job.
If this does not work, unplug printer cable for five minutes, restart computer, and if you still have no luck, reinstall drivers.
  • Ginko
    Ginko Nov 01, 2008
    If
    If
    Note, you do not need to uninstall the printer, leave it in there and add a new printer with same characteristics, then delete the old one.
    Ensure that you are logged in with administrator privileges while you perform this operations.
    Genius:
  • 3,422 Answers
HI,
Please reinstall your printer drivers.This should fix your problem.
Also make sure your cartridge is full.
And also unplug all the cords of your printer for 15 min and then plug it back in.Do this after you reinstall your drivers.
    Genius:
  • 1,250 Answers
How your printer icon is looking on control panel, if dim, it means it is not detecting , if normal it means detecting then,
go to control panel open printers, then open your printer, cancel all the documents, then send a print command and check
Dell Dimension 4550 and HP printer 2410. Everytime computer is turned on, it detects new hardware and reinstalls the printer, and repeats the process again. After that, the printer seems to work OK.
disconnect the printer, go into device manager and delete all the printers listed there. go onto the printer manufacturer website and download the drivers manually then install them. Hook the printer back up.
Aug 25, 2012 | Dell Computers & Internet
I have a Dell Dim 2400 and no connection with HP Deskjet 3070A.
Charles, has this combination worked previously, have you been able to print from your Dell Dimension 2400 to your HP Deskjet 3070A successfully?
If the answer to the above is Yes, then if you believe that the printer is still working correctly and you can test this with a different computer able to print to it, you should consider uninstalling and re-installing the HP software and device drivers for this printer.
If you have not printed to this printer successfully previously, have you tested the printer with a different computer and proven it is still working fine?
If the printer works fine to a different computer then providing you are using the same USB cable to connect to your Dell 2400, the problem needs to be narrowed down further.
Check that you can plus other USB devices into the port on the Dell used for the HP printer - if these work, then your USB port is good - if not, try another port if you have one.
If your USB hardware is good, then again you are left with the need to uninstall and re-install the HP software and device drivers - it may be worth trying to download the latest version of such software if available. HP tend to update their All-in-One software on a regular basis.
Dec 30, 2011 | Dell Dimension 2400 (24006YYVP31) PC...
How to remove computer cover
Try this website..this is a manual for Dell Dimension 2400 PC Desktop
it includes how to remove the cover of your tower. Check it out..
http://www.andovercg.com/datasheets/dell-dimension-2400-series.pdf
Sep 14, 2010 | Dell Dimension 2400 PC Desktop
How to turn my computer on, i found the power button but dont know what to do next
wireit all in as per instruction (if lost her they are http://www.andovercg.com/datasheets/dell-dimension-2400-series.pdf ) press the button on the front (above the dell logo) and hay presto all should work failing that conntact your supplier (where you brought it)
Nov 11, 2009 | Dell Dimension 2400 PC Desktop
Printer Spooler Problem ??
install new driver , search for it.
try a different cable for the printer, are you routing it from the scanner ? work the scanner.
go to trouble shooting see what it says.
go to adifferent port.
print a test page from the PC.
security setings from pc to router??????????
Vitally
Sep 10, 2009 | Dell Dimension 2400 PC Desktop
Everything I print is so small I can hardly read it.
when you go to print the window that pops up before it comes out will allow you to change the print size and the number of pages it goes on try that one
Apr 05, 2009 | Dell Dimension 1100 PC Desktop
My Dell Dimension 2400 does not recognize plug & play for my HP OfficeJet Pro L7650 all-in-one. If I add the all-in-one manually, the computer says it's offline. I've uninstalled & reinstalled the...
My solution was very simple...I just threw my computer out the window! Seriously, the problem has not been resolved...it seems that several types of Dell computers (in my case, the Dimension) have a problem with HP all-in-ones with regard to the USB 2.0 having enough power to recognize the plug and play option when installing the HP product. Dell's only solution (that I could find) is to operate the HP product thru a USB hub...so I guess I'll try that first and, if it still doesn't work, I'll probably just upgrade to a newer non-Dell Dimension computer.
Jul 15, 2008 | Dell Dimension 8200 PC Desktop
Start up problems
Normally, when the Dimension L-series gives a Press DEL to continue, it is an indication that the Hard Drive (Where data is stored) is failing.
At the Dell Screen when the system is 1st turned on, press CNTL+ALT+D to run a quick diagnostic on the hard drive. If there is a failure, you will get a failure code (Code 3, Code 4 etc) if the drive passes, no failure was detected (Doesn't mean one doesn't exists though)
To run more diagnostics, you can boot to the Dell Dimension Resource CD if you have it and run Dell Diagnostics from the CD.
May 12, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
70 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
