This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
SOURCE: Smeg fan oven not working, all other functions ok
You need to place use a multimeter to check the element for continuity if that is ok then the next step is to check for 240v being
switched to the fan and element array.
With the unit switched off at the wall put the test leads onto the correct points ( Use the earth post for the Black lead) switch the meter to a range to cover the 240vac and then switch on the unit
If there are no readings then you need to go back up the wiring to check the input to the thermostat
