Question about Carrier 38CKC042 Air Conditioner
Comfort 92 Gas heater Exhaust
My unit was installed with a eccentic exhaust (y shaped) for the air flow outside and water is runnig down the pipe draining back and coming out around a 90 degree elbow that was not glued and flowing down the outside of that pipe and dripping on to the floor on my garage. Shouldn't this exhaust pipe be angled to the outside so the natural flow would be to the outside and should the intake of the eccentric be connected to the intake of the gas furance.
  • 182 Answers
The slope is downwards to furnace.The slope isnt for the moisture it is a rise for the flue gas to go outside.The intake is usually connected to the furnace to use outside air for the combustion but it does not have to be.if it isnt an option to take the pipe apart to glue it all up you can seal the water leaks with silicon.anymore questions hillbuck29@aol.com
Posted on Nov 02, 2008
My frigidaire air conditioner is spitting water out the side and the drain hole is clear is there a secondary drain hole?
The tray that holds the condensed water from the evaporator
may be clogged, it may be clogged before the cleanout hole,
where the tray joins the pvc, if this is the case you may have to
power down your ac unit, there is a panel on your heater unit
that you will have to access to expose the evaporator coils and
you will see the tray where the condensation builds up and flows
thru a pvc pipe to go outside. also make sure that the pipe going
outside is at a slope so that the condensation can flow and not
clog the pipe. make sure that water can flow from the tray thru
the cleanout hole. once you correct the problem. you need to reseal all the seams with duct tape or metalic tape, you can purchase at most hardware stores, to make sure their are no ac
cool air leaks other than thru your ac vents. good luck!
Jul 30, 2011 | Frigidaire Heating & Cooling
My Mitsubishi Split air air Con leaks water (condensation) when operating. Every month or so I have to clean the water tray of water and blow out the drain pipe. It appears that on indstalation the...
Please note the drain line should be always downwards to flow water freely. Now you lift the indoor slightly from down locked, and take drain line out through any side of indoor. Now just after 6 or 9" after make hole (levelly down) and insert to outside. Or From outside, existing drainline can be run down words. Thanks.
Feb 26, 2011 | Mitsubishi MS09TW Air Conditioner
WATER LEAKING
Water should come out of the back of a wind unit when it is humid out, usually a drain hole. If water is leaking inside from a window unit, check that the outside drail hole is not clogged or maybe it is not tilted downward enough outside (Usually a very slight tilt down toward the outside to help the water drasin out the back outside). Also, if you have excess water forming, you may need to clean the coil. For central air units water should be drippng outside the home via a pipe or tubing and if the drain tube or pipe is clogged with scum that forms inside the pipe water will back up and overflow in the house near the heater/air conditioning unit. Also, some units have a pump to pump the water out and it may not be working.
Aug 07, 2010 | Heating & Cooling
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
My air conditioner unit is spitting out water when I turn it on. How can I fix this?
You have to recheck your installation. The unit should be installed in such a position the condensed water runs out to the drain pipe and goes out. Please first adjust the position and ensure that the front grill portion is kept higher than the rear portion allowing water to flow out to the drain pipe.
Remove the drain pipe and clean it so that there is no dust or insect blocking the free flow of drain water during condensation.
The above would enable your ac unit to throw cool breeze and not water!
Jul 10, 2009 | Heating & Cooling
LEAKING ON THE INSIDE OF THE HOUSE
There is an outlet to allow condensed water to flow outside the house from the AC unit runs. Please check whether there is any dust block in the tube and once you clean it water will flow out and not into the house. Sometime the garden lizard or flycatcher could get into the drain pipe and got stuck and block the outflow of condensed water.
Please ensure that the window air conditioner is installed in such a manner the out side portion of the unit is slanted or tilted to the back so that the water will run out and not into the room. By providing some pad to the front portion of the unit the above could be achieved and condensed water will not flow into the room.
Jul 08, 2009 | GE AJCQ08ACB Air Conditioner
The unit is leaking a lot of water from the bottom. What should I do? I do not see a drip pan and am not using the dehumidifier. It is vented to the outside but vent is raised up and not even with the...
All air conditioning units remove moister from the air.Which is good,it helps the moister on your skin evaporate faster,and helps cool you down.If its a central heat/cooling unit it should have some form of drain pipe to carry this moister away from the unit.Usually a white pvc tubing. Sometimes these become clogged with dirt,or even believe it not algae.If there is no drain someone didn't do the job right.(clean the gunk out of the pipe,or replace the tubing). If your talking about a window unit the unit will drain out the back of the unit,but the air conditioner has to be tilted in such a way that any water inside the unit will flow toward the back of the unit. (simply lower the outside end of the unit a little lower than the side stuck in the window).I see you mentioned a vent so you are probably talking about a air handling unit in your home.The vent should just be for fresh air.If you have a very tight house an air handling unit will be designed to bring fresh air into the house(to keep your air fresh).That is usually its only function.There should also be a small drain pipe leaving the unit somewhere.Some modern units even have a back up drain if the first clogs,and maybe even a signal that tells you the first pipe is clogged.
Jun 24, 2009 | Continental CEPAC1062-1 Portable 9800 BTU...
Excessive leaking
This is a condensation drain, The pipes were probably just pressed together. it is actually a T fitting . The tubes just need to be fitted together and pushed together. the lower pipe drains to the outside of the house and the one pointing up is just a vent so the water won't back up and a way to flush the lower pipe. Nothing serious, good luck
Jun 11, 2009 | Carrier 38CKC042 Air Conditioner
Condensation causing water collection
Hi there!
Make sure the unit is level and not tilted forwards.Tilt back if anything.
There should be a drain hole at the back, but it may be clogged, or there may be an obstruction causing the water to build up.
In times of high humidity, water will condense on the cooling coils, and drip off. This is usually carted away by means of a tray flowing to an outside pipe.
One design uses a flinger to catch any water and throw it onto the evaporator coils - thus improving efficiency, but if there is anything touching the coils, like a feather etc, it will flow down that and leak.
Tip it back as the first action, then investigate if it doesn't drain.
Jul 06, 2008 | Samsung AW0503B Air Conditioner
Leaking air conditioner unit
I suppose that the water is coming from the unit where the blower motor is. Condensation is created by the evaporator coil while its running and is suppose to drain into a pan under it and through a pipe to the outside. This pipe could be stopped up. The easiest way to fix that is to blow air through the pipe from the outside. It probably comes out close to the outside unit. It could be that your inside filter is dirty causing reduced air flow and making the evaporator freeze too. Change the filter. That may help. There are other steps that you could take if these don't help. Contact me by email if you need to. Cant run over there because I'm in Missouri but may be able to help in a chat room. kstfas@yahoo.com
Aug 15, 2007 | Goodman CLQ36AR49 Air Conditioner
Carrier 38CKC042 Air Conditioner Logo
100 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
