When the copier is swithched on it gives error code C2558 before the machine warms up
Help me my konico minolta bizhub 184/164 error (C2558)
my mail id - [email protected]
Open the side cover then on the machine, now you enter program, enter function, then you run f8 but before u run the f8 make sure u close down side cover back, imediatly u close d side cover press on f8 and press send butten, d developer will stabilize, you do that 2 to 3 time your machine will pick, if not you change developer
R 06, 2012
Answered
Minolta bizhub 164 error code C2558
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
SOURCE: Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
