Question about Nokia 1600 Cellular Phone
1200 not charging - Nokia 1600 Cellular Phone
  • 1 more comment
  • shafaqatlati Nov 01, 2008
    1200 not charging
  • sahilarora Feb 14, 2009
    i have the same prtoblem. my 1200 is not charging
  • provati May 08, 2009
    when i put charger, show not charging
    Problem Solver:
  • 6 Answers
1200 not charging
Posted on Dec 24, 2008
My nokia 1200 not charge
Posted on Nov 11, 2008
Change uem
Posted on Nov 03, 2008
I dont know how to charge my GARMIN nuvi 1200 with the usb cable
There are 3 ways to charge your garmin nuvi 1200 as follows;
  1. Connect your satnav to a computer with the mini USB cable. Plug the narrow end into the satnav, where the power cable goes, and the other end into the USB port of your computer. Both computer and satnav must be turned on. It will take about 8 hours to charge like this.
  2. Connect your satnav to your car charger and plug the charger into the cigarette lighter socket of your car. It will take about 4 hours to charge.
  3. You can get an optional mains charger which also takes 4 hours to charge the satnav.
May 23, 2011 | GPS
My battery will not charge on my honda GL 1200
If the battery is not charging could be stator or a cell broken down in the battery. Take out battery and try to charge it out of the bike on a trickle charger. If it wont charge in the bike there is a problem with the charging system and may be the stator or regulator.
Aug 16, 2010 | 1985 Honda GL 1200 Interstate Gold Wing
I have a p reg 1200 and charged the battery but it only turns over for a few seconds then i have to recharge. i have new plugs in.do i need a new batt? YUASA YTX12-BS CAME WITH THE BIKE
Sounds very much like the battery will not take a full charge and will need to be replaced. Check the voltage after charging and then again after use. A bike shop should be able to test it for you if you have not got access to a volt meter.
Feb 01, 2010 | 2002 Suzuki GSF 1200 Bandit S
i guess that means u cannot fix it u must change the interior charging pin.
Aug 13, 2009 | Cell Phones
Worked for a year, now says not charged when plugged in
Try to use a wall adapter and charge it for 4 hrs before you plug it in the car because it is much better if you use a wall adapter it gives more power.
Jun 09, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Starter on 1200 L 2006 whirs but does not engage engine to start
Have the battery LOAD tested, a lot of times a battery will show good with no load on it but it can actualy be bad when tested under load. Also make sure your grounds are good clean and tight. Loose grounds is a very common problem with the 1200 sportsters.
Apr 17, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
Not booting. possible charging problem??
the usb connector block on the unit may have actually broken off from the main board. I thought I had a charging problem too until I opened the unit.
Apr 13, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Dell Inspiron 1200 Charging Problem
Was the battery a Dell replacement? or was it a Chinese replacement battery?
Your charging circuit may have been damaged.
Oct 09, 2008 | Dell Inspiron 1200 14.1 XGA LCD...
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Nokia 1600 Cellular Phone Logo
309 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
Shehu Pro
Shehu Pro
