Question about Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
V-chip setting i brought a toshiba tv from a pawn shop it has a v-chip block on i do not know the code what can i do about it
  • CluelessTwo Nov 07, 2008
    I tried that, it didn't work. The V-chip on mine is blocking 3 TV channels :(
  • 934 Answers
Try this:
Turn Unit ON.
Set the DVD Mode.
Press and hold the 'STOP' key on the front panel.
Simultaneously press and hold the '7' key on the remote control unit.
Hold both keys for more than 3 seconds.
The On Screen Display message 'PASSWORD CLEAR' will appear.
The 4 digit password has now been cleared.
Bill
Posted on Nov 03, 2008
I bought mt tv at a pawn shop and want to set it back to factory default. I don't know the pin
there is no way to bypass the pin through settings, the only person that knows the pin is the one who set it. but one way to do it is to pull apart the tv, and find the watch battery or glass fuse that hold the memory for the tvs main board, pull this battery or fuse, and put it back in, and everything should be reset to factory defaults :)
Feb 21, 2015 | Toshiba 32AV500U 32 in. LCD HDTV
Colors have separated in my toshiba big screen. Don't even know where to start with this... Hopefully someone else does.
looks like u had something magnetic around tv,if u have digital cable box hooked 2 it, u may want 2 try swapping that out just 2 make sure it's not box, but prob. tv.look on craig's list 2 find another,or a pawn shop that way u don't have 2 put 2 much money into another,or watch sales at best buy but get warranty.i just deal with pawn shop cause ur taking chances even with new products & u won't have as much money forked over.good luck
Feb 15, 2013 | Televison & Video
Need code for the perntal code on the wii system it is on lock and can not connect to the internet brought from a pawn shop how do i get that or change it?
For the Wii, if you don't remember your parental control code, you can reset it using a "secret question" answer. Since you bought it from a pawn shop, you probably won't know this either. In that case, you'll have to contact Nintendo Support, they can help you with the problem. Included below is a link to the page where you can contact Nintendo Support. Just scroll down the page and select the "Contact Nintendo" button, and there are step by step instructions from there.
http://www.nintendo.com/consumer/systems/wii/en_na/settingsParentalControls.jsp#reset
Good Luck!
Jul 07, 2011 | Nintendo Wii Console
Need to reset v-chip code JVC t.v. vcr combo 2000
I got a jvc tv-13142 at a pawn shop but some of the channel is blocked and i need a vchip code to unlock it i try all zeros and it show error how do i reset code
Jan 22, 2010 | JVC TV-13142 13 in. TV/VCR Combo
I brought a toshiba from the pawn shop and i tried to change from windows xp to windows vista how can i find a hard drive disk to install windows vista
You don't need to replace the Hard drive in the laptop, you can usually upgrade, or install vista from the CD-ROM / DVD-Rom.
If your laptop does not have a DVD drive to install vista, you may use file sharing to install it from another computer on the network. To do this follow these steps:
1) Place the Vista DVD in second computer
2) right-click on the DVD-drive that has the Vista DVD in it, and select " Share..."
3) You may need to press the "Advanced sharing" button to enable sharing, if so, do that, and just hit the " apply " button
4) OK out of all of those menues
5) on your laptop open " my computer" and click the " map network drive "
6) browse to the location of your drive on the other computer, and click " OK "
7) install Windows vista
If you do however need a new hard drive for your laptop, you can usually get them from any PC store such as Bestbuy, fry's, or online from places such as NewEGG.com, and Tigerdirect.com.
You will need to know what type of hard drive you have, and how to replace it. The manual for your laptop usually has this type of information.
SIDE NOTE:
When putting Vista on a laptop, be sure it meets the minimum requirements.
May 30, 2009 | Toshiba Satellite® A75-S276 (PSA70U005004)...
V chip reset
i need to reset my sons v-chip how do i do that,he has a toshiba tv.
Sep 27, 2008 | RCA T20TF667 20 in. TV/VCR Combo
I have a toshiba tv model:19a21 and i want to unlock the v-chip. i did not activate the v-chip i was like that when i bought the tv what can i do to reset it
To reset the V-Chip on the Toshiba 19A21:
Hold the volume down on the TV - at the same time, press the number 1 on the remote. The TV will turn off and reset everything.
Jun 22, 2008 | Toshiba Televison & Video
V-chip code forgotten
I found this to work on my Toshiba TV/VHS combo MV19M4 after trying others suggestions that had worked on similar models but nothing worked on mine. Maybe it will work for yours. Follow these steps:
1: Unplug the TV for 1 minute then plug it back in.
2: In the menu select "TV Set Up".
3: Move the blinking block to beside "V-CHIP Set" BUT DO NOT SELECT IT.
4: Hold in the number 1 button on the remote.
5: Hold in the volume down button on the TV.
Your TV will turn off. Give it a few seconds to reset itself and then turn it back on and you will have to completely reprogram your settings. When you go to the V-CHIP settings it will ask for your new code.
- Jenny
Nov 01, 2007 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
I forgot password for V-Chip / reset V-Chip
my brother greeting from belize lift the eeprom from out of the set and and resolder it back, it will have reset it self good luck.
Apr 03, 2007 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
Memorex mvt 2135b
Either a clock battery on the board (soldered in) or jumper inside. There was a remote code for hard reset, but I cannot find it. See if the website has support and email them for the code.
Apr 08, 2007 | Memorex MVT2135 13 in. TV/VCR Combo
Toshiba MW24FM1 24 in. TV/VCR/DVD Combo Logo
142 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
