Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
LG dishwasher LDS5811ST
Dishwasher worked great for first 12 months, on month 13, has lost power, won't turn on when the power button is pushed but then, a day or so later, will suddenly turn on and go through a cycle without anyone turning it on.
  • Anonymous Jan 05, 2009
    My dishwasher makes the same humming noise. It's almost like the motor is whining.
  • Anonymous Apr 19, 2009
    I've had mine for about 3 years and and just recently, I pressed the power button and nothing happens. I just submitted a request for an on-site repair person to look at it. According to the site, the controller board is warrantied for 5 years.
  • 423 Answers
The problem with the dishwasher acting haunted is probably the main controller card. If you don;t have an extended waranty, know that LG will cover the parts for free through 24 months but after 12 months, the labor will be charged.
Posted on Apr 04, 2009
How do I replace dishwasher door hinge spring?
http://www.repairclinic.com/PartDetail/b200p9/LG-Dishwasher-Hinge-Spring/4970ED4004D/1337779?modelNumber=LDS5811ST#repairHelpVideoTabs
Oct 07, 2014 | LG Dishwashers
Lg dishwasher no heat
http://www.repairclinic.com/PartDetail/b200p9/LG-Dishwasher-Heating-Element/5301DD1001G/1582252?modelNumber=LDS5811ST#repairHelpVideoTabs
Jul 11, 2014 | LG 24 in. LDS 5811ST Stainless Steel...
LG dishwasher model # LDS5811ST won't turn on
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | LG Dishwashers
LG dishwasher model LDS4821- 16 months old- getting E1 error. Water leaking on floor. This happened before 3 months ago but then had no other problems with it until now. No other problems with this machine...
Hi ferrojennife,
The E1 you are seeing means Water Level in Drum lowering, this means there is a leak on one of the pipes. More likely it is the Circulation Pump, which is responsible for pushing the water to the Spray arms.
It will have to be replaced, as it is a common spare that has to be replaced on L.G Dishwashers (lifetime expectancy: 12 - 18 Months) - Not very expensive.
Usually is about 20%-25% the price of a new Dishwasher. The Circulation pump is fitted to the sump. Part Number: 5859DD9001A or 5859ED1001A (Depending which one is in stock)
See below a image of what a Circulation Pump looks like:
Good Luck :-) - J.Q
* If you found this solution helpful, please vote for it
Jun 09, 2011 | LG LDS4821BB 24 in Builtin Dishwasher
I have a LG Dishwasher Model LDS5811ST. The code
Did you find anything out? Mine won't drain either.
May 14, 2010 | Dishwashers
Will not come on.
Since the LG LDFxxxx family, including the 9810 all have a power button (and not just a door handle interlock switch that turns the unit on when you close the door, you have an internal problem that will not have a quick fix.
This dishwasher had a 12 month parts and labor and a 24 month parts-only warranty. If you have proof of purchase, I recommend you contact the LG support number in the owner's manual.
Good Luck!
May 24, 2009 | LG LDF9810ST Built-in Dishwasher
Lg - LDS5811ST Dishwasher OE Error Code
hi
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
May 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Maytag Dishwasher
we have a model mdvtt53aww1 and you can push three buttons and will light up the hi temp wash, heated dry and sanitize is there a code make it start
Oct 01, 2007 | Dishwashers
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
491 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
