Question about Philips PSS110/17 MP3 Player
Displays "Problem!Please connect to computer"
When switched on, the product displays "Problem!Please connect to computer"
  • 8,596 Answers
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
Posted on Mar 23, 2009
My pc displays only green light and the fans do work but it doesnt display
Check if the computer has onboard video as well as a video card. You may have connected the monitor cable to the wrong port. If this does not work, reset the jumper switch to reset the bios.
Aug 18, 2014 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
HELP PLEASE!!! NEC NP-V260 Computer In can not detect signal from the Computer
Which connection type are you trying to use (VGA, HDMI, etc). It would help to know what kind of computer you are using and whether you are using the projector as the only display or trying to do multiple displays.</br>
If using a laptop then check and see if you have a key to switch displays. It will usually be one of the function keys (F4, F5, etc) and will most likely be a secondary action of the key requiring you to hold down your FN key then push the function key. This will switch between your laptop's outputs.</br>
If using a desktop you need to go to your display properties. Win7 right click the desktop and go to Screen Resolution. You need to make sure that the Multiple Displays setting is set to Duplicate These Displays or Extend These Displays to make sure that the display adapter is sending a signal to the projector.
Jun 28, 2012 | NEC V260 DLP SVGA Projector
I have connected my monitor to a kvm switch but it displays nothing on screen...please help
If you are getting no video then either the KVM Switch is not transmitting video or the cable is defective. I would recommend checking with the supplier of the KVM Switch you are using.
Jan 18, 2012 | HP TFT7600 Rackmount KVM Switch
I cannot clear the "Door
Hi
When you open the print cartridge access door there is a black toggle switch that needs to be in the depressed position to let the unit know the door is closed. If the cartridge door is not completely closed, the error message displays.
1. Open, and then close the cartridge door of the product. Make sure that the door rests securely against the body of the product.
NOTE: To see how to close the cartridge door of your specific model, see the cartridge section of your product's User Guide.
2. Check the product control panel to see if the error message still displays.
If the issue persists, see the next step.
Check the cartridge door for obstructions
1.Inspect the door and the area around it to make sure that no obstructions prevent the door from closing completely.
NOTE: Bits of paper, packing materials, and tape might prevent the door from closing completely.
2. Remove any obstructions.
3. Check the product control panel to see if the error message still displays.
If the problem still persists you need to reset the product...
1.Press the Power button to turn on the product.
2.Disconnect the USB cable from the back of the product.
3.Disconnect the power cord from the electrical outlet.
4.Disconnect the power cord from the product.
5.Wait 30 seconds.
6.Reconnect the power cord to the electrical outlet.
7.Reconnect the power cord to the product.
8.Press the Power button to turn on the product.
9.Reconnect the USB cable to the product.
10.Check the product control panel to see if the error message still displays.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 10, 2011 | HP OfficeJet 7130 All-In-One Printer
Hi, i am currently installing a EPSON Stylus COLOR 1520 but am having difficulty downloading drivers for Windows Vista. COuld you please help where i could download form? Thanks, Mike
Follow these steps to set up your Epson product and install the built-in Windows Vista drivers:
  1. Set up your computer.
  2. Connect your Epson product to your computer.
  3. Follow the on-screen instructions that Windows Vista displays to guide you through product driver installation.
OR
You can try the download option from this link : Driver Link
Thank you for contacting FixYa
*Please rate this solution with thumbs up
Nov 16, 2010 | Epson Stylus 1520 InkJet Color Printer
How do I have the printer recognize the router so I can print from my laptop from another room please? I have a C27250
Make a wireless connection between an HP all-in-one with built-in wireless networking capability and a functional wireless network with an access point (router) that is SecureEZSetup enabled.
Connecting the unit to the computer
  1. Activate SecureEzSetup on the access point (router). Usually this is accomplished by pressing a button on the access point. Refer to the router or access point documentation for specific instructions.
  2. Press the Setup button on the all-in-one.
  3. Press the arrow buttons until Network displays and then press OK . The Network menu displays.
  4. Press the arrow buttons until Wireless Setup Wizard displays and then press OK .
  5. Follow the instructions in the Wireless Setup Wizard.
  6. After the all-in-one connects to the network, install the product software on the computer.
Regards,
Rizwan
Jan 19, 2010 | HP Photosmart C7250 All-In-One Thermal...
Can't scan
To test the hardware, use the product to copy a document.
1.open the scanner lid.
2.put a document face down on the glass.
3.close the scanner lid.
4.press the copy button.
make sure that the product connects to the network
ethernet connection
1.Disconnect the network cable from the back of the product, and then wait a few seconds.
2.Reconnect the network cable to the back of the product.
3.Make sure the other end of the network cable connects securely to the router or switch
4.Make sure that the lights on the router or switch are on.
5.Continue to "Step three: Print a network configuration page and find the IP address."
wireless network
  1. Make sure that the router or access point is on.
  2. Position the router or access point closer to the product.
  3. On the product, press the setup button , and then select the network option.
  4. Select the wireless setup wizard option. The product searches for the router or access point.
  5. Select the 'enter the new network name'(SSID) option.
  6. Type the service set identifier (SSID) or the name for the wireless network, and then select 'done' . The product searches for the network.
  7. Select the relevant authentication protocol, also called the security mode. Supported protocols include WEP (64 bit and 128 bit) and WPA-PSK (WPA1 or WPA2, AES or TKIP). Networks that do not use an access point or a router, known as ad hoc networks, support WEP encryption only.
  8. If the network uses media access control (MAC) address filtering, make sure that you have the router or access point set to allow the MAC address for the HP product.
  9. Follow the instructions to configure the product for your method of network security:
  10. WPE: Log on to the router or access point from the computer, and then find the wired equivalent policy (WEP) key set within the router or access point. If you specify the WEP by using 10 or 26 hexadecimal characters, make sure that the characters are 0-9 and A-F. Use the on-screen keyboard on the control panel display to type the WEP key on the product.
  11. WPA: Log on to the router or access point from the computer, and then find the Wi-Fi Protected Access (WPA) passphrase set within the router or access point. Use the on-screen keyboard on the control panel display to type the correct WPA passphrase.
make sure that the product is connecting to the network, print a network configuration page from the product and find the IP address on the page.
1.On the product control panel, press the Setup button
2.Select Network , select Network Settings , and then select either Print Network Settings or Print Network Configuration Page . The network configuration page prints
3.Make a note of the IP address for the wired or wireless connection. The IP address should resemble the example: http://192.168.1.1
4.If the computer connects to the Internet using a wired connection, the IP address displays in the Wired section.
5.If the computer connects to the Internet using a wireless connection, the IP address displays in the Wireless section
Jul 21, 2009 | HP Officejet 4315 All-in-One Printer
I cant find the HP psc 2210xi driver when I bought a new computer with Vista
go here and pick the operating system you have then download the software that you require
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=79502&lc=en&cc=us&dlc=en&lang=en&cc=us
Robert
Please take a moment to rate this solution.. thanks
Jan 29, 2009 | HP PSC 2210 All-In-One InkJet Printer
HELP HELP HELP!!!!
Sounds like the firmware has corrupted. Install and run the Firmware Update software from the product CD.
Select the repair option and follow the on-screen prompts. This will re-load the firmware and should get your player working again.
Feb 20, 2008 | Philips GoGear SA178 MP3 Player
Philips PSS110/17 MP3 Player Logo
242 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
