Question about Olevia LT37HVS 37 in. LCD HDTV
Need a repair shop in NY for out of warranty Olevia
Olevia is flickering all the time - even without cable connection, the blue screen keeps flickering - I understand this might be a power suppy/invertor issue. Instead of sending it to Olevia in california, Is there a repair shop I can go in NY city?
Thanks,
Pratik
  • tebon77 Nov 01, 2008
    Any idea how much the approximate cost of the repair would be?
    President:
  • 624 Answers
Just about any TV repair shop in NY city can fix it for you unless it is under warranty. If it is under warranty, let me know and I will look up an authorized service center for you. But you do not need an authorized service center if it is not under warranty.
Posted on Nov 01, 2008
  • Dave DeGain
    Dave DeGain Nov 01, 2008
    Try this place, it is empire TV in NYC, very good reputation.
    212.431.5338
    200 Hudson St. (at Canal)
    New York, NY 10013
  • Dave DeGain
    It is hard to say with any certainty how much it would cost without knowing exactly what the cause of the problem is. I would expect to pay at least $150 and maybe as much as $300, but you should be able to get an estimate from the repair center before you commit to paying a repair cost. Some shops charge for an estimate and others do not. I can tell you that when you pay for an estimate, you will get a more accurate estimate. If you get a free estimate, the shop will not want to use the technician to figure out what is wrong with the unit since they still must pay the tech even if you refuse the estimate. So free estimates are really just a free guess and are normally higher than what the repair would actually cost.. A paid estimate is more reliable and will most likely save you money in the long run.
The screen will flicker sometimes go completely white.. Is there a problem that needs to be addressed immediately?
the lcd cable that joins the screen to the motherboard is most probably faulty. To fix it you need a new ribbon cable. Samsung will charge to sort it without warranty however the NC10 has a 12 month warranty so check your receipt date. Failing that a local computer shop is likely to be the cheapest option.
Jun 22, 2010 | Samsung NC10-14GW Notebook
Acer Laptop Screen Flickers & Jumps
Please connect the laptop to an external monitor. If no flickering on monitor screen, from my previous experience, this is more likely loose connection of video cable connected to the LCD. So talk to Acer support again and require the replacement of LCD.
CompQ
May 11, 2010 | Acer Aspire 6930-6082 Notebook PC
The top screen of my Nintendo DS Lite keeps flickering
This is most likely caused by either a loose connection or a faulty screen.
If it's under warranty i'd suggest sendng it in otherwise you can either take it to a local repair shop or repair it yourself.
Firstly when you take the ds apart disconnect the top screen and then re-attatch it just to be sure if its the connection or not, if a re-connection works then your sorted... if not you will have to replace the screen.
The screen can be bought from ebay. You will also have to do a bit of soldering as the speakers will need to be removed from the old screen and soldered onto the new one.
If you need any more help with changing the screen then give me a message and I will do my best to help you out.
Feb 06, 2010 | Nintendo DS Lite Console
Olevia 237-T12
Might need a Digital converter box as it looks like it has no QAM tuner..
Jan 06, 2018 | Olevia LT42HVi 42 in. LCD Television
Olevia LT 37 HVS HDMI PORT
You need to take the unit to an authorized repair shop to have it
check and correct it , looks like the power supply section got affected by the sudden change of voltage and damaged an internal part, hope this helps , AJ
Jul 02, 2008 | Olevia LT37HVS 37 in. LCD HDTV
My laptop monitor flickers
Don't worry about embarrassment, there's a world of difference between software and hardware.
The flickering is most likely either a loose wire or more likely a partially snapped dry solder joint where the florescent panel behind the screen is connected. Since the laptop lid is opened and closed frequently, even the smallest of movements over several years can stress a dry solder joint to the point where it cracks.
Unfortunately it's not a user serviceable thing, but you may not need to return it to HP - a local specialist in flatscreens or more ideally monitors is likely to be able to mend it. Since it's so far out of warranty anyway it's not too much of a risk to use someone not HP approved since they can't invalidate a warranty that's long expired, so get your local phonebook out and start searching for someone who can give you a quote on a flatscreen backlight repair.
May 29, 2008 | HP Compaq Presario V2000 Notebook
Olevia lt 30 hv
You both need to IMMEDIATELY download your warranty from the Olevia website. Read it completely. If you are still under warranty, then contact them IMMEDIATELY in writing pursuant to the warranty and demand that they fix the TV for free pursuant to the warranty. Do not accept "No" for an answer. Document every communication and contact you make, including date, time, who you spoke with (first and last name and/or employee number), and the content of the communication.
Do not delay on contacting them, because the warranty is controlled by the date you purchased the TV. If it passes, then you are totally screwed. Olevia will ignore you.
ALTERNATE SOLUTION:
Do not buy any Olevia or Syntax products in the future. Tell everyone you know to not buy their products either.
Dec 24, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 26" flat screen
screen suddenly shut off. blue light in the right hand corner stays on but there is no picture
Dec 17, 2007 | Olevia LT26HVX 26 in. LCD Television
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
Olevia LT37HVS 37 in. LCD HDTV Logo
222 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
