Question about Sony VPL-VW100 (Ruby) Multimedia Projector
Sony Projector OK here is how it goes there is a repeating pattern of flashes: everytime the green (standby) light flashes 9 or 10 times the orange (Lamp cover) flashes one time. 4 green flashes after the orange flashes once, there will be 4 to 5 clicks inside the unit. If and when the lamp comes on it will be as a result of those 4 to 5 clicks inside the unit. Last night, after several atempts (I also do the reset routine [reset,<,>,enter] which does not seem to have any effect) we were able to watch TV all night no problem. Thanks for your effort Hubert
  • propar Dec 10, 2008
    I have exactly the same problem... Could I get the training and troubleshooting manual as well... Thank you...
    propar@macconnect.com
  • cryptonic Dec 16, 2008
    i, too, have this exact same problem. please send me the manual as well
  • 320 Answers
Ok we're back to the flashing lamp cover LED. The green flashes you are seeing is the TV trying to start up. After it tries for awhile, it will eventually shut down and display an error code, in this case, the lamp cover LED flashing which means either the lamp cover, filter cover or main cabinet sensing switches are not closed, are intermittent or have some kind of wiring issue. A solid lamp cover light (no flashing) would point to the lamp and lamp drive, but the flashing light points to the switches. Give me an email address and I'll send you the training and troubleshooting manual so you can see for yourself. Any ther help needed, please don't hesitate to ask.
Posted on Nov 01, 2008
My Sony VPL-VW100 has a problem turning on, that's only worsened throughout this year. It will give a series of 4 audible clicks, the green and orange lights will intermittently flash -- and will repeat this pattern about a half dozen times before it gives up. If I'm persistent and go thru this cycle several times, it almost always comes on -- except when the media room is hot [usually in excess of 85 deg F].
Is this something I can fix myself, or does it require send in / tear down. When functioning properly, the Ruby gives no indications that the lamp or filter are reaching their end of life. I've cleaned the filter, that did not work.
Thanks in advance for your help, I can be best reached at fitchbuck@qwest.net and 253-891-2855.
Gary Wulkowicz
Posted on Aug 15, 2009
I have the exact same problems after replacing the bulb, occasionally it starts but usually it clicks a few times with the green light flashing and then the lamp cover light flashes orange once. please could you send me the instructions as well to brian_turner@mac.com
Posted on Dec 27, 2008
I am also Having a similar problem can you send me the training and troubleshooting manual. cb(@)avinterior.com
Posted on Nov 03, 2008
On/Standby light flashes red four times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 27, 2012 | Sony VPL-EX100 3LCD Projector VPLEX100
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Sony Trinitron KV-28LS36U no sound or picture, the standby light flashing green and red but if i switch it on a little bit of sound comes and then switches off. how can i repair?
The unit is shutting itself down because a problem was detected internally. When this happens, the standby light should blink a repeated pattern. Please count the number of blinks and post the number here. That will indicate the circuit in which the problem occurred.
Thanks,
Dan
May 19, 2009 | Sony Televison & Video
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KDF 60WF655 standby/power light blights 10 times then repeat
This is what I found
You may want to have a Tv repair shop look at this .
Standby light flashes 10X
Symptoms / Customer Description
[Primary Symptom Code: 2111 ]
Solution
G1 and G2 boards are ok.
Found Q box was causing loss of DTL MODULE 5v.
Replaced Q box to resolve.
Part #
A1058689A
Feb 09, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Nov 12, 2007 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
Sony VPL-VW100 (Ruby) Multimedia Projector Logo
778 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
