Question about ASUS K8S-MX Motherboard
Motherbord Bios & Driver Download
Please Send m the Proper bios update and driver
  • Anonymous Nov 01, 2008
    its ar bad graphig
Just go to asus site and dowload the required drivers for your HDD detectuion. This is not found uin manty systems but u have 2 install raid drivers at XP installation.
Posted on Feb 17, 2009
Pls sir give me problem for solution.....
sata HDD found not detect,sata HDD detecton for RAID,pls give me answer sata HDD properlly detect.
Asus Chipset K8S-MX &MBD model 965l
Posted on Dec 18, 2008
Sata hdd not dectet
Posted on Dec 03, 2008
    Master:
    Sergeant:
  • 461 Answers
Not sure what model of your asus m/board.. please provide details...
or perhap you can check below site if there is any model related to your motherboard issue...
http://etech.maiila.com
Posted on Nov 01, 2008
Vertical lines and discoloration on my sony vaio vgn a140
It is required to get the BIOS and the Video Driver Updated in the Computer to resolve the issue.
The BIOS Update and Video Driver Update are available at Sony Support Site for download.
You can view and download the BIOS Update from this link
Before installing the BIOS update, be sure the computer is running from AC power. If the installation of the BIOS is interrupted by power loss, the computer may not operate correctly or at all.
During the installation of this update:
  • Do not turn the computer off.
  • Do not allow the computer to enter Standby or Hibernation states.
  • Do not start other programs.
  • Do not connect any peripherals.
Download the AIBSYS-00772903-US.EXE file to a temporary or download directory.
Go to the directory where the file was downloaded and double-click the "AIBSYS-00772903-US.EXE" file to begin the installation.
At the "BIOS Update Utility for Microsoft® Windows® XP" box, click "Next".
At the "License Agreement" dialog, read the agreement, then, if you agree, click "I Agree" to continue with the installation.
NOTE:
Please wait while the utility extracts the necessary files for the update.
At the "VAIO BIOS Update Tool 1.0.01.10181" box, click "Update".
At the "WBFLASH" box, click "OK".
NOTE:
Please wait while the utility updates the BIOS.
At the "WBFLASH" BIOS Update successfully completed box , click "OK" to shutdown the computer.
After the computer shuts down, wait for a few seconds, and then power on the computer.
After the computer restarts, the installation of the BIOS Update is complete.
After installing the BIOS Update, it is required to Update the Video Driver to resolve the issue.
You can view and download the Video Driver Update from this link
Download the ATDVID-00610812-US.EXE file to a temporary or download directory (please note this directory for reference).
Go to the directory where the file was downloaded and double-click the ATDVID-00610812-US.EXE file to begin the installation.
Then, please follow the onscreen instructions to complete the installation.
After installing the Video Driver Update, please restart the Computer for the settings to take the effect.
Performing the above steps should fix the issue.
If the issue is not resolved, please check if the Vertical lines and discoloration are visible while accessing the BIOS Setup Utility.
To access the BIOS Window, please restart the Computer, press and hold the F2 Key to access the BIOS Setup Utility.
If the lines and discoloration are available on the BIOS Setup Utility window, the issue may be related to the LCD Screen of the Computer and you will need to get the Computer serviced to fix it.
In that case, you can contact Sony Service Center get the Computer serviced and resolve the issue.
Apr 14, 2010 | Sony VAIO VGN-A140 PC Notebook
Audio driver problm
if you have a motherboard driver cd try to install from it or else search in the company website of asus to get the driver for the operating system you want .sometimes driver may not installing since you installed the driver which is not supported in that case uninstall any drivers installed for audio and install the recommended driver
Mar 03, 2010 | ASUS P5GC-MX/1333 Motherboard
Problem with my Asus p5pe-vm motherbord.When i start it,the message CPU uCode loading error appears.What to do...HELPPPPPPP
If your over clocking your CPU settings reset to default. See if you still get the error. If you still get the error than update your bios. There are a couple of way to do this. You can use the software on your Asus CD or you can down load the latest BIOS-Utilities, Afudos BIOS update tool V2.36. Than download the bios file, P5PE-VM BIOS 1501.
http://www.asus.com/product.aspx?P_ID=k3h0ZFVu9Lo1dUvk&content=download
Using built-in EZ Flash to flash BIOS Please be informed that not all motherboards support EZ Flash,
please use DOS flash utility to update BIOS if your motherboard does not support EZ Flash; http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=960&SLanguage=en-us
Happy holidays!
Mike
Dec 19, 2009 | ASUS P5PE-VM Motherboard
I want manual and bios of Asus motherboard model
Here's the link to the driver and bios updates. Hope it helps you.
http://bios-and-system-update.free-driver-download.com/ASUS/12467/ASUS-Mainboard-P4PE-BP-BIOS-1007.html
Mar 29, 2009 | ASUS P4PE-BP Motherboard
Asus k8v-vm mother board drivers
boot block compatible version ver 003
bad bios checksum, start recovery
is alone window seen in my computer
Dec 26, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Bios update
go online and type in
bois download drivers
enter
manifacture name bois model # [date if u have one] download drivers
rod
Dec 16, 2008 | ASUS P4S800-MX Motherboard
MOTHERBORD BIOS
Since you didn't spell Mercury correctly I'm going to assume that it was a mistake to place the ' G " in PIG as the only thing I can find that looks like your system is the PI865GVM-L version 3.00 at this Mercury motherboard website http://www.mercury-pc.com/downloads_list.php?productid=425. I have a strong feeling this is what you are looking for but I tried the bios update file as a download and it seems to be inoperative at the time I tried it. Make sure you verify the version of whatever you download is correct and proper for YOUR motherboard, else you might lose some functionality even with very similar boards.
Aug 10, 2008 | Computers & Internet
Bios update
make sure your bios is an eprom. people download bios upgrades only to find their bios is not a flash bios. that is it doesn't have the infrared source to physically "flash" the chip.
Sep 13, 2007 | ASUS P4S800-MX Motherboard
ASUS K8S-MX Motherboard Logo
412 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
