Question about HP LaserJet 3055 All-In-One Printer
Hp 3055-scanner function
When i try to use the scanner it say "not set up for pc"
  • chellzz Nov 03, 2008
    This machine has worked fine until last week. When I try to scan a message comes up "not setup on pc". Nothing has changes that I'm aware of?? It did this once before a week ago and I fixed it somehow.
  • Anonymous Nov 10, 2008
    I need to set up scanner to scan.
Soulvisitor
  • 1113 Answers
SOURCE: HP LaserJet 3055
The print drivers might be ok but have you updated and installed new Vista Scanner software as well as Print Drivers
Posted on Oct 21, 2007
SOURCE: Scanning on HP 3055 printer/scanner/fxx doesn't wrk with vista
I am unable to scan in pdf format under vista window
Posted on Mar 23, 2009
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
  • 8404 Answers
SOURCE: I want to set up my HP 3055 scanner so that it connects with PC
This is an interesting question ... Im thinking maybe even a trick question ...
You want your scanner to not connect with the PC? Don't plug the printer USB into the PC - vola - no connection. The scanner will scan without relying on the PC and the copy function is the same.
Posted on Mar 19, 2010
popsgifts
  • 160 Answers
SOURCE: laser jet 3055 scanner error 6
Generally, Error 6 is a failure of one of the PCA boards and the unit requires service.
Posted on Apr 20, 2010
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
Jul 06, 2015 | HP LaserJet 3052 All-In-One Printer
Hi, the problem is i can not scan with the HP laserJet 3055 it prints via wireless with no problem but it says no set up on PC
You have to run the FULL setup on each machine for the scanner to work correctly. PLUG and play DOES NOT WORK very well, in that printing us the only function that works.... Go to HP.com and download and run the latest install software for your setup.
May 02, 2011 | HP LaserJet 3055 All-In-One Printer
How do I fix "Not
This error indicates that the scanner has not been linked to the desktop of the attached PC. Either launch the HP Toolbox and follow the scanner setup instructions, or if you do not have toolbox installed you will need to install the printer from the original disks that came with it.
Mar 29, 2011 | HP LaserJet 3055 All-In-One Printer
Mar 19, 2010 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
3055 scanner not working
My HP 3055 cannot scan but can print & fax.
Nov 02, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055
i've upgraded my vista printer drivers and all and it still doesn't work ont he same model. i used to run this printer on a XP but working on seperate computer can be too crumblesome. since it's a plug and play on vista with this printer.. my solution is go to windows photo gallery. under the FILE - hit import scanner / camera. - it will auto read ur scan feature. but before that. just make sure u install a scanner onto ur windows . by going to control panels and set up scanner. - connect printer to computer first when u do that. it will rauto read ur printer. the drivers just owuldn't work but the windos software helps to elimiinate the problem.
Oct 19, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
902 people viewed this question
Seeker5211
Seeker5211
