Question about Samsung RS2534 Side by Side Refrigerator
Freezer stopped working
Our Samsung fridge is not the exact same model as this , its a (RS2544SL) but exactly the same thing happened last nite .I left the door ajar and everything melted now the freezer does not work.Ive tried to make it work and have called Samsung(thats another story)This is not the first time this has happened with this fridge , the freezer stopped working in the first 2 months of ownership and before a service guy could come around (2 days ) it started working again. This time no luck so far ...the fridge is now 2 years old and not covered by full warranty! Any ideas?
  • 1 more comment
  • steve huber Sep 22, 2006
    Thanks Catriver
    I assume by dryer that you mean the evaporator? unless we are talking about a totally different appliance.My exact model is as stated in my original problem is a RS2544SL u.s.a side by side.Well guess what !!! it started working again yesterday about 24 hours after it stopped. I have done some other research on this unit and some think that it may be a circuit board problem , however I find your answer interesting and it also explains the intermintancy of the problem. The short and finally rude answer from Samsung was to refer me to Maytag repair ($140 call out fee) to find out wether it will be covered by the 5 year sealed unit warranty....this ignores the fact we have lost $300 worth of food ..twice!Please let me know if you have any more info on this problem and thanks again for your help.Apparently im not the only one that has had problems like this , with an otherwise good fridge.
  • jinq Dec 29, 2008
    We have the same rpoblem with model RS267LA. We should not import freezer from Samsung
  • Anonymous Mar 31, 2014
    The freezer is still working fine so we left the fridge over the weekend and tried it again last night and it worked briefly then stopped again. Is this something I can fix easily myself as I don't wish to waste a large amount of money on unnecessary call out fees.
    President:
  • 878 Answers
Solomonau, it's hard to tell without being there exactly what is going on. I do know however,that in April of 2005 Samsung came out with a bullitin regarding the cap tube. It states that it has been inserted into the dryer incorrectly and can cause no cool situations. This is part of the sealed system which should be covered for 5 years. What you are describing sounds like a partial restriction, which could be taking place in that dryer and cap tube. If you were to post your model number, I would be able to tell if yours was included in this bullitin. You can then contact Samsung and inquire about this service bullitin, Catriver..post back.
Posted on Sep 20, 2006
SOURCE:
Motor constantly running stops when door of either fridge or freezer is opened but starts again when door is closed - Samsung Silver Nano
It's possible that your fridge has a fan to cool down faster your food and to prevent frost. It stops when you open the door to to avoid losing the cold.
Il you send me the exact model (for example RS7568THCSP/WS) I can add a more precise explanation.
Sep 12, 2013 | Samsung Refrigerators
Model rs2544sl no cooling
Try resetting the frig by holding the power freeze and power cool buttons down at the same time.
Jun 12, 2017 | Samsung 24.8 Cu. Ft. Side-by-Side...
Unit stopped dead.no lights in both fridge and freezer. Does not run. checked power plugged into another circuit still nothing
The exact same thing happened to me. An LG service tech was sent to my home, only to tell me that he couldnt fix the problem.. a blown fuse. He said the entier fridge had to be replaced. You would think a blown fuse owuld be an easy fix, but evidentally not. LG did replace the appliance but after it was replaced they told me theyd only guarantee the new fridge for 90 days. After that, my extended service plan would come into effect. Good thing Id purchased that plan because my 90 days was up last month & now my ice maker has quit working. I will never buy another LG product!
Oct 19, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
All of a sudden stopped getting cold in the fridge portion, freezer is fine
If you completely defrost the freezer and restart the unit and it doesn't get cold in the refrig portion it could be the internal fan that moves cold air from the freezer to the frig area if it does get cold after an hour or so then it is probably the defrost coil needs replacing. I am not familar with your exact model but this senario applies to many different units.
Apr 18, 2009 | Refrigerators
Fridge & Freezer not cooling
You will need to change the complete control pc board.
Mar 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Samsung RM255LASH - flashing error code 98 a8 after power glitch
Just happened to me with a power flash- fixed it by pressing and holding the Freezer and Frig buttons together until the screen flashed and reset. Wheww! Though it was a gonner! Fine now:) Hope it works for you!
Nov 06, 2008 | Samsung RM255LASH Side by Side...
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Samsung RS2534 Side by Side Refrigerator Logo
352 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
