My Logik L22LID628 tv has an intermitant fault & will sometimes not respond to the remote control, I have tried new batteries, and checked the remote control by tuning an infra red light switch to the remote control power/on button which works fine.
  • 1 more comment
  • pushka001 Nov 13, 2008
    The 1st night I watched the TV all was fine till suddenly the picture went grainy, a pink line ran from the top to the bottom of the screen, and a very loud alarm sounded. The TV didn't respond to the remote control, to switch it off or anything so I had to switch the power off at the mains (plug).
    The next day there was no picture at all on the TV, only sound, and it doesn't appear to be responding to the remote control again.
    I purchased my Logik TV yesterday. It was working fine until mid evening when it suddenly sounded a very loud alarm, the picture went grainy and a pink line appeared from the top to the bottom of the screen. The TV wouldn't respond to my switching it off via the R/C, so I switched it off at the mains (plug). When I switched it back on again all was well.
    Today when I tried to watch tv there was no picture, just sound. Any clues as to what may have happened?
  • Anonymous Dec 07, 2008
    Same problem, tv picture freezes without warning, screen goes grainy without warning and sometimes has a loud audio scretch to accompany the picture problems. The tv also does not respond to the remote nor the standby button on the actual tv meaning it has to be switched off at the mains and turned on again. Sometimes it happens continually maybe 10 times and other times no problem for a number of days, in any case it's only 1 mth old so it's going back tomorrow !!!
We have had two of these tvs break within 2 days of purchase, in our case both times it seems to be a backlight failure. Did you wall mount your tv? If so when you take the base off it leaves a hole in the casing leaving circuitry visible. I think it's very easy to damage the ciruitry.
Posted on Nov 03, 2008
My fire stick remote won’t respond to Alexa commands from remote
hi Douglas298.
this is all i could find.
Fire TV Remote NOT Responding / Syncing / Connecting: SOLVED I've changed the Fire TV Voice Remote control batteries 5 times already but it still keeps disconnecting and now it's gone completely dead! Update 08/02/17: The most probable cause for your Fire TV remote not working is going to be the batteries. I know, you're thinking I've already changed the batteries twice already. The Fire TV remote is a fickle beast and only likes brand new fully charged batteries before it will re-connect to your Fire TV box. I've tried switching in batteries from other devices that are all working fine, but without any success. Brand new batteries are the key for this power hungry remote.
Has your Amazon Fire TV Box or Fire TV Stick become slow? See my Fire TV Slowdown Solution here.
This need for new batteries seems to be especially true when your Fire TV box is next to a complicated TV setup with AV, Speakers, WiFi Router all next to each other.
AMAZON FIRE TV 4K
AMAZON FIRE TV STICK
If you've tried brand new out of the packet batteries and it's still not working then you might have the same issue I had below. Don't forget to ask any questions you might have in the comments beneath this article.
Update: You can now control you Fire TV Device with the Amazon Echo & Amazon Echo Dot
If you've felt the annoyance of your Fire TV Voice Remote suddenly not connecting then I know how you feel. I've owned a Fire TV since October 2014 and up to now it's handled everything I've thrown at it. This is until one day last week when the remote suddenly kept disconnecting then died completely showing no signs of life.
I went through an array of different fixes to try and get it to work again but then finally I had a brainwave and managed to bring the remote back to life. It wasn't through trawling internet blogs and YouTube videos that I found this solution, it was actually from inspecting the remote more carefully. No, it wasn't Amazon's fault for building inferior products it was actually my own fault and partly the fault of cheap pound stores that litter the UK.
When I took the battery compartment off the Fire TV remote it looked completely normal. It wasn't until I raised the remote up to eye level that I noticed that there was a slight chalky residue on the connectors of the battery compartment. It then dawned on me as I looked across the room at a packet cheap pound shop batteries. One of the cheap batteries had leaked battery acid on to the Fire TV remote connectors blocking the current from getting through.
How to use your Fire TV when the remote won't turn on?
Luckily, Amazon have an App for that called Amazon Fire TV Remote that is available in the Android App Store and the Apple App Store. You can then control the Fire TV using the app and proceed to the next step below.
How to check if your Fire TV remote is connected to your Fire TV?
To see if your Fire TV remote is connecting to your Fire TV box or dongle you need to head to the settings menu.
  1. Settings > Controllers and Bluetooth Devices.
  2. Amazon Fire TV Remotes
This will show you what devices are currently paired and from here you can see if your remote is connecting. In my case when fiddling with the batteries my remote would appear here for a few minutes then disappear.
If all else fails, you can get an official Amazon FireTV Remote replacement.
The Solution
I took a flat head screwdriver and gently scraped the connectors of the Remote at each end. Wiping the residue off with a dry cloth as I scraped. The connector should look shiny and new again at the end of this process. I placed the batteries back in and the remote connected again straight away.
I've had no problems with the remote since and I guess the moral of the story is sometimes you get what you pay for... utter leaky batteries this time.
Fire TV Quick Tips
  1. Hold down the Select button for 5 seconds to put the remote into pair mode.
  2. Hold down the Select + Play buttons together for 5 seconds to Restart the device.
  3. Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in.
  4. or try this link.
fire stick remote wont respond to Alexa commands from remote Google Search
Nov 29, 2017 | Televison & Video
I have a rm 88e. Tv codes for logik tv please. Please
2018,2005,2031. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 24, 2016 | Televison & Video
Why does my Logic tv keep freezing? The remote stops working, I can't turn over channels or use the volume control and sometimes get a green band across 1/2 the screen. Please Help!
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced.
Sep 07, 2014 | Televison & Video
What is the sky remote code for Logik L24FED13?
0039.0033. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Mar 22, 2014 | Televison & Video
Remote control not working brand new sony rm-lj301 remote
Check the remote control for its infra-red emission. Even new pieces might have the fault. You can check its infra-red emission, by a mobile phone having camera option. If you wish to get more details about how to check a remote control, check this link.http://electronicshelponline.blogspot.com/ If the remote control emits infra-red emission, and still TV do not respond to it, the fault will be due to a damaged infrared sensor inside TV. This part can be located just behind the infrared window at the front panel of the TV set. You have to open the TV, to access it and to replace with a new one. The part will look somewhat like these.
Jun 11, 2013 | Televison & Video
The remote will not turn on the Bose System intermitently.Need to turn the power off for TV & Bose unit & then back on for it to work.
If your system is plugged into a surge protecter, the Bose service guy told me that sometimes the Bose system detects a surge and automatically shuts down. Unplug the system for 5 minutes and then plug back in. This works because it happened to my system. I called Bose and this is what I was told. It worked!
Dec 27, 2012 | Bose Solo TV sound system - Black
Bravia kdl52ex700 volume control doesn't work
Look for any jammed buttons on remote, any obstruction like a sticker or gum on the sensor on the TV. If you have such obstructions, the TV will respond only partially.
Aug 15, 2012 | Sony Televison & Video
Remote does not work even with new batteries. Pressing the keys on the TV makes the TV work.
I know this may sound silly but check first the new batteries are in the right way around, secondly some remote control have a TV/VCR switch to operate both equipment, make sure it is in the TV position (you did not mention the model of your TV, only certain models have this on the remote). If it still does not work the infra red sensor may be at fault inside the remote, you can take the remote apart & try to resolder it but it can sometimes be a bit awkward.
Jul 06, 2009 | Toshiba Televison & Video
Intermitent fault TV does not respond to remote - sometimes power off then on from remote corrects this Sometimes not even TV buttons work - have to switch off at plug to correct
sounds like there's a fault somewhere in the circuit board for this to be happening - i can"t pin point esac were it is Sorry But Hope Im Been Somewhat Helpful
Jul 07, 2008 | Televison & Video
Televison & Video Logo
499 people viewed this question
Top Televison & Video Experts
Electro Med Services...
