Question about HP Color LaserJet 5500n Printer
Printer HP 5500n 57.x error
When the printer initialises it comes up with a 57.x error and takes me through opening and closing all the panels on the front. However, this does not solve the problem. The manual suggests a fan failure. The printer was opened and indeed one of the fans on the left side did not spin-up. Now Im not sure whether it is always on or driven by a small thermostat. The fan was removed and tested and it was faulty. However, replacing it with a working fan does not solve the error. By the way, even the new fan does not spin when the printer is switched on. Any ideas?
  • 22 Answers
ITS THE FAN UNDER THE TOP COVER THAT EXHAUSTS THE FORMATTER
Posted on Jun 24, 2008
  • TRANSCORP99 Jun 24, 2008
    ITS THE FORMATTER FAN UNDER THE TOP COVER
We are getting a 51.2Y error on a HP color LaserJet 5500n What can we do?
51 is a printer error.
51.2 is a laser error
51.2Y don't know. Can't find any errors that end in a "Y".
Be that as it may, press the check mark on the operator panel to continue.
Try power cycling the printer.
Could have a defective laser/scanner assembly or a bad DC Controller.
Sorry I can't be of more help.
Mar 04, 2011 | Office Equipment & Supplies
Had a paper jam - now removed but comes up with an error 5703
57.XX ERROR Control Panel Message 57.XX ERROR For help press c00244025.gif alternates with To continue turn off then on Description A temporary printing error occurred in one of the printer fans. Action Turn the printer power off and then on. If the message persists, contact an HP-authorized service or support provider. Click here to locate an HP-authorized service or support provider via the HP Web site at http://welcome.hp.com/country/us/en/wwcontact.html.
Feb 21, 2011 | HP LaserJet 2420 Printer
Scanner Error 5 "error message" on my all in one
I had this problem and it had to do with the scan bulb head not recognising the marker. My temporary fix until the bulb is replaced is to turn the printer off, open the top (ADF and all) with the gray button on the right so that it's slightly raised and then switch the printer on. When it comes up, just close and print/scan/copy as usual. Apparently the spring in the arm warped the interior surface where the head moves and it can't line up when it's closed. Hope this helps.
Jun 07, 2010 | HP LaserJet 2840 Printer
I get an error in HP LaserJet 4345 MFP printer, 49.ff95 error, Tunr off and the turn on
a 49.xxxx error on an HP means that there is an issue with one or more hard disks. you can try to re-initialise the hard disk(s) by rebooting the printer while holding the green button. when the three leds are lit, release the green button, and navigate using the numerical buttons until you see "initialise hard disks" on the display of the printer. confirm by pressing the green button again. if all goes well, your printer will take two minutes longer than usual to boot. if you still get the same error afterwards, you need to replace the disk.
Apr 21, 2010 | HP LaserJet M4345 MultiFunction Printer
HP Designjet 4000ps printhead error
Plz Sir
Stape :: 1
Your Printer Cover Open Few Minitus
Stape :: 2
Plz Chek Your Printer Property .... And Delete Your Own Page
Stape :: 3 Plz Check Printer Property And Port Tab Chenge Selected Port
Enjoy
Aug 17, 2009 | HP DesignJet 1055cm InkJet Printer
I get an error message saying 10.99.00 carterages not engaged and i open and close cover but i still have the same prob
if you printer is connected to a computer
try printing a cartridge alignment sheet from the
printer properties,you will find it under the maintenance tab
also you may try taking out all the cartridges
turning off the printer
turn it on
and one by one put the cartridge back
and then let it initialise
try it and let me know if that helps
Jun 13, 2009 | HP Color LaserJet 3500 Printer
Printer lid open light is coming on when printer lid is closed
The printer lid error can appear if any of the following are true:
- top lid is open
- rear duplexer or flat panel is not installed correctly
- cartridge bay area door is open
All of these conditions are detected by a series of sensors or circuits in the printer design so with regard to the lid and cartridge bad door you need to make sure that nothing has broken off that closes the switch.
I'd lay odds that it's most likey the rear panel/duplex unit. I'd recommend taking this out as per the manuals instructions and then reinserting it, carefully so that it fits in place properly.
Hope that solves your problem.
Martin
May 19, 2009 | HP Officejet Pro K850 InkJet Printer
HP 5500n 59.ck error code
HP LASER PRINTER 2300 ERROR 59.B, 59.C
1. The Alienation motor error.
2. Replace the alienation motor.
3. Replace the D.C. controller board.
May 15, 2009 | Office Equipment & Supplies
Change ink cartradge 11ER00670, same error after new cartradge.
SYSTEM NEED TO BE RESET, CARTRIDGE MAYBE DEFECTICE, THE SWITCH MAYBE A PROBLEM, GO ONE LINE AND SEE IF ANYONE ELSE SEEN THESE TYPES OF PROBLEMS, GO ONLINE AND TYPE:
XEROX PHASER 5500N LASER PRINTER CARTRIDGE ERROR 11ER00670
ENTER
IF THAT WAS THE ERROR NUMBER YOU HAD
OR
XEROX PHASER 5500N LAZER PRINTER CARTRIDGE ERRORS
ENTER
OR
XEROX FOREM GROUP
ENTER
OR
MANUFACTURE NAME,MAKE,MODEL, DRIVERS AND SERVICE MANUAL
ENTER
ROD
Feb 09, 2009 | Xerox Phaser 5500N Laser Printer
Hp printer 5500n
the magenta laser scanner is defective and needs replaced.
Jun 02, 2008 | HP LaserJet 5500DN Printer
HP Color LaserJet 5500n Printer Logo
241 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
